Cylinder interchangeability '85 3.2 Carrera/ 3.3 Turbo
Hello,
I am considering taking my 1985 3.2 Carrera Cylinders (95mm) to get bored to 97mm (3.3 L) and then re-plated For my turbo build. I will then buy 97mm (CR ~ 7.0:1) pistons. Thus I have fully finned 3.3 turbo pistons and cylinders. My question is, are the cylinders identical and interchangeable so that the 7.0:1 compression ratio is maintained, and is this setup viable?
Thank you all so much for your help
Andrew
Old 10-05-2010, 06:00 PM
Chain fence eating turbo
I have 930 P&C's on my '87 if that helps any.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-06-2010, 12:00 AM
EBS_Don's Avatar
These will fit with no issues at all. If you're boring and plating you may want to consider just going up to 98mm and getting a 7.5:1 or 8:1 compression piston set. Anything to help out low end response is a good thing!
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 10-06-2010, 08:59 AM
Awesome, Thanks again!
Andrew
Old 10-07-2010, 10:21 AM
Tags
fully finned cylinders , turbo cylinders
