Front oil cooler line size?
I am trying to get my 914/6 chassis ready while I wait on a few other engine parts and am planning on adding a front oil cooler. The cooler I have has -12 line ends on it and from what I read, this seems to be large enough, but others have used -14. Is the larger diameter necessary? Adds more weight overall when you run from front to back, but if the flow is necessary, it is a no brainer. FYI i have a 4 rib carerra pump for this engine, if that matters for scavenge side? Will be 2.4 S basically when done.
2000 VW TDI 224HP/400FT TQ.
Pikes Peak World Record Holder 2007 "Fastest Diesel Car"
1973 Porsche 914/6 2.4L Engine rebuild in progress
Old 10-07-2010, 06:39 PM
Puny Bird
Mark Henry's Avatar
The -12 is fine.
There's a guy over on the 914world.com site thats selling the 914 GT hard line kits. Many threads and pic's on front cooler set ups over there as well.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 10-08-2010, 02:41 PM
Don't think there is a -14AN.
Main consideration should be smaller "out" and larger back "in".
So if you use -12 out to the remote cooler then use -16 from the dry sump tank back to the motor.
On my race car I use -16 and -20.
Tom B.
Old 10-08-2010, 04:22 PM
Try not, Do or Do not
Henry Schmidt's Avatar
-12 oil lines are adequate for 2.4 making up to 270hp.
We used a different method for cooling an original 914-6 with a 240 hp 3.0.
We employed a simple sandwich plate, -12 stainless line and a Mazda cooler with a built in thermostat.
The customer wanted to keep the chassis as original as possible, therefore no extra holes. The original deck lid was saved to restore the car to factory original.
The engine never had temperature issues even in California on a hot day.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-08-2010, 05:06 PM
Puny Bird
Mark Henry's Avatar
Henry, wouldn't that pre-heat the cooling air?
Interesting set up, I have a RX-7 cooler just like that and the ports are smaller size than -12. Did you weld bigger ports onto it?
I'm building a a 3.0 with 9.7 RSR (style) malhe pistons, is that twin plug? Can you share some of the details on the build?
Old 10-08-2010, 08:29 PM
Not enough to matter appearently.
I made special fittings to addapt the AN to metric threads.
It's been 6-7 years since we built that project. I have no idea what the build specs were, sorry.
Henry Schmidt
Ph: 760-728-3062
Old 10-08-2010, 08:48 PM
Walt Fricke's Avatar
Agree -12 should be fine both ways. It is roughly the same ID as the stock 911 front cooler lines.
It is when you have a remote sump tank that a larger diameter return line has merit. It is under very little pressue, and may even be negative - you can buy a coil spring insert if collapse becomes an issue. -16 is the most common for that, although -12 worked fine for me until I switched to -16.
Old 10-10-2010, 08:24 AM
So the consensus is that -12 or -16 would be the correct size to use on the scavenge side for a front mount cooler? Will use a Mocal thermostat as well, but want to plan ahead and order the correct stuff.
Old 10-11-2010, 06:02 AM
Puny Bird
Mark Henry's Avatar
-12 is fine, remember when you run to a front cooler the return is not going to the engine... it runs back to the sump tank. Then it goes the short run from the tank to the engine.
Really you should check out 914world.com, massive wealth of 914 knowledge over there.
We don't bite.
Old 10-11-2010, 07:52 AM
Am already member there for some time...thanks for the invite. I just wanted to be sure about the 911 oil pump specific size so I do not some how starve the engine of oil or have too much restriction.
Old 10-11-2010, 09:13 AM
I used -12 on mine. I do like the radiused 90deg fittings when you need one. .....
JPIII
Early Boxster
Old 10-11-2010, 07:04 PM
Great snakes, JP!
The only thing better than using the heater ducting to get oil lines up front and back is to run one on one side of the car, and the other on the other. That way you don't have the outgoing hot oil heating up the returning cooler oil.
Walt
Old 10-11-2010, 10:22 PM
Walt: there's a couple of congested areas on the 914 for oil line routing.
One is just below the front motor mount and the other is around the pedal cluster.
Both would become involved with the either side routing method so I took the easy way.
JPIII
Early Boxster
Old 10-12-2010, 04:36 PM
Either way, you don't have to worry about someone crushing an oil line with a floor jack.
Old 10-12-2010, 10:23 PM
johnman001's Avatar
I used the heater tubes as well. I also opened up the two "conduits" into the front trunk more or less like the GT cars to route the oil lines into the front trunk. There is a small closed box section just to the outside of the pedal cluster on the drivers side and another on the passenger side.
This does introduce hot oil line(s) into the passenger compartment, but they are protected from external dangers and a small cover plate can be used over the oil line to protect your feet.
The GT cars used hard lines in this location.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 10-13-2010, 10:17 AM
Here's a pic (or 2) of mine heading forward.
A gratuitous plug: All this oil system is going on the market soon. The old 2 valve motor (it goes also) just won't cut the mustard vs the 4-500hp monsters in XP. Time to go mutli-cultural mix of Japanses & German. .....
JPIII
Early Boxster
Old 10-13-2010, 05:06 PM
