engine shroud paint?
My 2.2 engine has a black fiberglass engine shroud. Any special paint needed to spray paint it?
Old 10-26-2010, 04:59 PM
Max Sluiter
Flieger's Avatar
The original color is a fiberglass gel coat, so it goes all the way through the material. The way it used to be was red = S, green = E, and yellow = T. On CIS cars from 1973.5 onwards, they were black.
Are you sure it is black? If so, others can give their experiences with paint. If not, it can be sanded and polished to bring back the original gel coat.
Old 10-26-2010, 05:04 PM
A portion of the black is worn off and underneath is gray
Old 10-26-2010, 05:42 PM
Max Sluiter
Flieger's Avatar
Sounds like a later shroud.
Old 10-26-2010, 05:51 PM
Less brakes, more gas!
euro911sc's Avatar
I used Krylon in a can and it came out great. Repaired the glass cracks/breaks. Sanded, filled w/ light body fill, sanded smooth, primed, painted. Cake.
Lots of threads on this with pics; not just mine.
You cannot get it back to factory look w/o molding your own brand new shroud as the color is embedded in the resin of the glass...
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-26-2010, 06:23 PM
Max Sluiter
Flieger's Avatar
If the original is the color you want, you can restore it by sanding and polishing.
Old 10-26-2010, 06:47 PM
Thanks all
Thank you
Old 10-26-2010, 06:58 PM
