How to measure compression?
I've got some aris pistons which look to have high domes and large pockets for clearance. How would you go about measuring for compression ratio? I will have the engine apart soon and will have to do this. How high can I go with compression before it will blow up? The engine will be twin plugged. At what compression do you need to run race gas? If I decide to run race gas how high can I go with the compression? How much better will the cooling system have to be in an engine like this?
Old 11-12-2010, 05:57 PM
I would rather be driving
jpnovak's Avatar
here is my method for measuring the dome volume on a piston.
Install top two rings on piston.
smear liberal coat of grease around top ring.
insert piston into cylinder
invert cylinder on top of a flat hard surface (I use a granite tile)
push piston through cylinder until top of crown touches said hard flat surface
flip piston/cylinder combo upright
Measure the depth of the piston outer edge from lip of cylinder sealing surface
Make plastic cover that is larger than the diameter of the piston sealing surface
smear grease on the perimeter of the cylinder sealing surface
place plastic cover with two holes drilled at edges of cylinder bore on top of cylinder
use a buret or graduated cylinder to fill the void area under the cover
record volume of liquid used to fill void area (Be ACCURATE)
Calculate the swept volume of the piston dome (use piston depth and cylinder diameter)
subtract measured volume (using the liquid) from the swept volume to determine the piston some volume
Repeat volume measuring process for cylinder heads.
Using crank stroke, piston diameter, dome volume, deck height (installed) and cylinder head volume calculate the compression ratio.
Too many variables to answer your questions regarding maximum compression ratio. Type of cam, temperatures during driving, street or track, etc must be factored in. I would err on the low CR value for longevity and peace of mind.
Yes, you will need more cooling. however, modern technology for controlling mixture (EFI) and internal engine coatings can help reduce the thermal dissipation requirements of the engine.
Old 11-12-2010, 06:46 PM
Could you repeat that? Only kidding. Wow not so easy.
Old 11-13-2010, 04:32 AM
Will be running either ge60 cams expensive. Or will use 911s cams cheap. So which ones would you run for Drivers Education and autocross events?
Old 11-13-2010, 04:35 AM
How will they effect compression?
neilca's Avatar
The cam does not effect static compression. It is simply an equation of volumes. You do have to consider the cam when you get to checking piston to valve clearance. Check out this post for more info.
Piston to Valve clearance with Solex cams
Old 11-13-2010, 06:05 AM
Arrow
Porsche 356 Registry: Calculating Compression Ratios
How to check engine compression ratio
Calculating an Engines Compression Ratio
RSR Static Compression Ratio Calculator
United Engine & Machine Co. Incorporated
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-13-2010, 11:13 AM
