Brando
split case
So I resplit the case as I forgot to install the nose bearing o ring. Do I need to get a new flywheel seal and pully seal too? I used the curel t sealant and it looks to almost damage the rubber seal outer surface to make it tight.
Thanks |
Look at "The complete engine sealant thread" here to see what and where to apply the different sealants. I believe most "in-the-know" folks recommend putting in the front and rear seals dry. I don't see why you couldn't re-use the seals you have if they are not damaged.
Lindy |
If it's damaged then I'd replace. What seal do you have? Is it the red one marked silicone? I believe the brown seal is better.
