KTL KTL is offline
Schleprock
KTL's Avatar
If you have the ability to install the new guides for 8mm valves, I say go for it. Anything you can do to lighten the valvetrain is an improvement as long as it doesn't compromise strength/durability. I doubt there's any downside to the 8mm valve stems since that's the size the 993 valvetrain uses?
Kevin L
'86 Carrera "Larry"
Old 04-03-2013, 08:49 AM
Puny Bird
Mark Henry's Avatar
The Aircooled bug Type1 and and type4 engines I build have 3X the spring pressures that these engines have. The reason for that is in a bug engine you're tossing the weight of the valve, pushrod and the lifter. The performance bugs I build have no problem surviving with 8mm valve stems, My bus engine, that has been in 4 cars now, has 80K miles on it.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-04-2013, 05:42 AM
Straight shooter
Lapkritis's Avatar
Playing devils advocate on smaller valve stem - there will be less area for the valve to contact the guide and to conduct heat away from the body and head of the valve. If you're looking at stainless then you will need to know your EGT to ensure it doesn't often surpass the failure point of stainless around 1500F.
In reality I imagine you would be fine with stainless and smaller stem with the correct guide spec unless you were pressing into the most extreme conditions...and even then you may not see 1500F EGT without a power adder.
Good info on valve materials - http://www.manleyperformance.com/dl/custom_valves.pdf
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-04-2013, 08:15 AM
Puny Bird
Mark Henry's Avatar
I don't have a EGT tester but I do have a wideband.
Thanks for the info
Instead of custom I can use stainless steel 993 valves, they have a short tip, so I'd have to shim up the springs depending on type. Cutting the head to stock size OD is no issue except for a small back-cut.
Old 04-04-2013, 08:27 AM
Puny Bird
Mark Henry's Avatar
I have a message to Walt Frickle, he did this and hopefully he'll chime in on his experience.
Old 04-04-2013, 10:38 AM
