Targa Time's Avatar
Cleaning Fluid
I bought a parts cleaner to clean many of the engine parts of my rebuild myself. Question is what solvent should I use? I looked at some waterbased cleaners, but they state that it will harm aluminum. I had someone else recommend mineral spirits, but it is combustable and the manual for the parts cleaner states "no flammable or combustable cleaning fluids.
What should I use?
Old 12-10-2010, 03:15 PM
E-85 sippin drunk
turbobrat930's Avatar
Mineral spirits.... nothing else... I bought a parts cleaning tank form Northern Tool, Same as the Harbor Freight one.... for around $100 bucks... I use about 15 gallons or so of pure mineral spirits for the last 10 years... only changed out the fluid once... Works great
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 12-10-2010, 04:43 PM
mineral spirits works, there are threads on this.... diesel fuel has been described as working pretty well and doesn't cost too much but may need soaking
Old 12-10-2010, 06:47 PM
peppy's Avatar
I am a fan of kerosene with ATF added, just because it is cheap and the smell is not too bad.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 12-11-2010, 09:26 AM
Targa Time's Avatar
Kerosine and ATF...wow who thought of that mix?
Anyway I went ahead and bought 10 gal. of Mineral Spirits and am currently out in my driveway clean parts.
Thank for your input. The Mineral Spirits seem to be working OK. I thought it might clean a little faster. But that might be because its 25 deg. outside.
Old 12-11-2010, 11:17 AM
Mineral spirits, also called ******** Solvent.
Works well, cleans off easily, isn't terribly flammable, and doesn't leave everything smelling bad.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Last edited by Steve@Rennsport; 12-11-2010 at 11:49 AM.. Reason: The name was blocked as its the same name as a Porsche dealer in Ohio
Old 12-11-2010, 11:49 AM
Chain fence eating turbo
Naphtha is what I used, works great.
Old 12-11-2010, 09:15 PM
