Case through bolts
I think I have a leaking upper case through bolt on my 993tt motor. Does anyone know if it is possible to replace the seals and re-torque the bolts w/o taking the cylinders off? My guess is that it is not.
Ken
Old 11-26-2013, 09:10 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Cylinders are mostly in the way. It's the heads that actually get in the way the most.
Some good pictures of thru bolt proximity to cylinders and the head in this topic
Your opinion wanted. Green bolt through viton o-rings with rtv
Kevin L
'86 Carrera "Larry"
Old 11-26-2013, 09:52 AM
Thanks Kevin
Old 11-30-2013, 07:49 AM
Ken
Nossir,...the 3.6 motor requires cylinder removal to gain access to the through-bolts.
BTDT, many many many times.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-30-2013, 09:52 AM
Thanks Steve
Old 12-01-2013, 04:24 PM
