911S 2.2 cam grind choice?
I have enjoyed reading all the threads but I have not been able to answer my questions. I am looking for suggestions on the best cam for solid low and medium RPM torque and drivability (safe but spirited driving and maybe an auto cross).
I have a 1970, T case, stock T crank, Webber 40's and good 2.2S p&c, I have read about the E, Solex and S cams and am leaning toward an E or Solex grind???
-What issues will I have to deal with running the above cams with my 2.2S p&c?
-What recommended "improvements" should I include on this engine rebuild?
ie. 2.0T heads re-worked to?
distributor?
-Any thoughts on assembled performance?
Thank You - for your suggestions and Happy New Year!
Bill
'70 914-6 (enjoyed my car since 1978).
Old 01-08-2011, 11:18 PM
BURN-BROS's Avatar
Welcome Bill,
You have a couple of nice choices from Dougherty racing cams.
DC30 (mod solex)
DC40 (mod S)
Based on what you are looking for, go with the DC30 as it gives you a little both the E and S.
Heads.... 2.0 liter heads would need to be modded to fit 2.2. Better solution is to source a set of 2.2-2.4 heads. A much better head.
Case savers, piston squirters,oil bypass mod and a 3.0 liter oil pump would be on my list.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-09-2011, 09:43 AM
distributor?
Bill
Hi Bill,
Just to add some additional thoughts to Aaron's,.....
If you want "solid low & medium RPM torque", your best choices are either your stock T cams or perhaps an E cam. This fit the "mission" better than Solex or Mod- S.
2.0 heads are the worst heads (powerwise) Porsche made; your 2.2 heads can either be used as is with the T or E-cams for max torque and throttle response, or opened up to match a Solex or Mod-S cam.
Those 2.2S pistons will really help you due to their compression ratio, however be careful about ignition advance with T or E cams, given CA's poor gas.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-09-2011, 04:38 PM
Thank you Aaron and Steve for your guidance.
This is solid informtion for my rebuild.
I will keep you informed.
Bill S.
Old 01-09-2011, 07:24 PM
