ALEX P
Hi
It's taking shape but still not in yet - I was waiting for a couple of bits back from the paint shop & I dont think the muffler will fit without a slight modification.I'm terrified to actually turn the key now & the amount of varying advice about run in procedures is pretty baffling but hopefully not too long to go! ![]()
ALEX P
Getting closer - finishing one job always creates another three though!
Hi Alex,
I am curious how you timed the cams and chains + crank + dist ? Patrick |
ALEX P
Hi Patrick,
There were three areas in rebuilding the engine that terrified me: 1. Sealing the case halves properly 2. Getting the timing right 3. Incorrectly torquing something or missing something. When I took my heads to be machined along with some other parts for checking, I got a price for assembling the bottom end - which then escalated into me taking the lazy but safe option of getting the whole long block rebuilt for me by a professional. I would have loved to do it myself but realistically it would have taken me forever and because of the risk and the figures involved, I took the decision to get it done. By methodically disassembling the engine, cleaning measuring and checking each component part did save quite a lot on the rebuild cost and you learn a lot about it at the same time. Sorry I can't be more help! Are you looking at or in the process of rebuilding? |
I would love to see more details (pics and measurements) about the engine tin and rear crossmember mods you did they look real clean.
1981 911sc RoW Coupe (forever under 3.6L conversion) 2003 996TT Basalt black |
ALEX P
Hi
Trust me, as shown above I'm no expert but I think that you will be fine with the cam profile and the stock valves and pistons. The only reason that I had problems was because of the oversize inlet valves. It also didn't help that the engine had been rebuilt previously so it had even more material removed from the heads.The rear crossmember was a very simple mod - it was bent on a press (as it's a 964 engine going into a 1985 chassis) then to strengthen it I had a couple of plates welded to the weakest area (where it is thinnest) and then powder coated satin black & it came out very well. I wasn't going to bother as most dont but when I bent it I realised just how weak the ends of the crossmember are and they do occasionally break here so for what is a simple, inexpensive mod, it's pretty worthwhile in my opinion. As far as the tin goes, mine was pretty shot and replacement tin can be very expensive so I went for the fibreglass as it's lighter, cheaper and DOESN'T RUST! Whether it all stays in one piece is to be seen but I like it. It was made by a local chap who took moulds from an old set of 964 tin and reproduced them in a very high quality weave of fibreglass. they're fairly flexible until it's all together then surprisingly rigid. As always there's some fettling for fit but something to think about if your tin is shot. I've added a couple of pics below but if you want any specifics, let me know. ![]() ![]() ![]() ![]() ![]() ![]()
ALEX P
915 Gearbox clutch cable fixing lug broken
Well, now the engine is in place I thought I'd start hooking some bits up starting with the gear selector and clutch.
I assembled the clutch levers and hooked the cable in place when but when I started to tighten the cable in position the mounting lug snapped clean off. I would like to stress that I was just nipping it up not leaning on it or overtightening it at all. I'm looking for any opinions on fixing this as I REALLY don't want to have to drop the engine again. Do you think I would be able to JB weld the lug back in place and use an ally or steel plate across the whole area as a type of washer to spread the load instead of the stock washers? Has anyone seen this happen before? ![]() Edit: Just been informed that it's a seperate bracket part # 915 116 613 01 and costs very little. My heart sank when I first did it and I had to walk away, should have looked properly!! Last edited by ALEX P; 07-14-2011 at 01:53 AM.. |
ALEX P
Cranks but won't start - Flywheel sensor?
Quick update - Engine cranks but won't start. I can't hear the fuel pump and there was no fuel to the bleed on the fuel rail so I tryed to jump the DME relay without success and also tryed my spare DME relay. When I try to jump the DME, all I get is a click from the engine bay???
Next step was to connect the positive terminal of the battery to fuse no.6 (fuel pump) and the pump happily whirred away so somehow I am not getting any signal to the fuel pump. I have been advised that it could well be the flywheel / crank reference sensor giving the problem as this activates the DME relay but havent got a clue how to test this. Does this sound like a likely reason and should I be checking anything else before I go and spend out on a new flywheel sensor? Exhaust is on upside down by the way to clear the mounting bracket until my spacers arrive!
HI Alex
have you still got the diagnostic socket fitted to the wiring loom? if so I will be near Silverstone to work on a 2.7RS on Sunday and if poss could call round with the diagnostic tester and plug it if for you, give me a ring 07885 622051 regards mike |
ALEX P
Hi Mike, sorry we didn't get to catch up on Sunday but thanks for taking the time to point me in the right direction earlier :-)
I've got a couple of ideas to try and will report back. Cheers Alex |
ALEX P
Vacuum lines
Quick update - Got the engine started and given it a bit of a run in. Also finished putting bumpers etc so car is getting there.
Pictures by ALEX-P76 - Photobucket It's not ticking over very well and is very jittery at low rpm but seems fine when it gets to around 2750rpm and beyond. As well as this it is running very rich which leads me to believe that it could be a vacuum problem. I don't think there are any leaks but it is possible that a pipe is incorrect. Vacuum lines are a real nightmare as they seem to change from early to late 964's, tiptronic, C2 or C4 so it's really confusing. I've been through PET and the workshop manual and have a diagram for a VRAM system but was wondering if anyone had a good diagram of some good photos or an early 964 engine's vacuum lines?
I just recently took apart and cleaned my intake. Check out my photobucket.com page for some pics. This is from a 1992 C2 Convertible, tiptronic. Hope it helps.
911 pictures by NoEardGoat - Photobucket
ALEX P
Thanks for that NoEaredGoat
![]() Gives me a good idea for some of the lines but my engine is the earlier 964 with the aluminium manifold so there are quite a few differences. Good luck with your build BTW, one thing that I did read that made me wince was that you were not planning on replacing your headstuds - That was what got me into this whole mess in the first place!! |
Which head studs did your motor have and how many miles? I think some of the early 964's came with Dilavar studs and the later (my motor) came with steel studs, which from what I have been told are good, but not as good as raceware, arp, or supertec studs.
ALEX P
I had dilavar studs in mine which had chipped paint and corrosion which led to failure. Couldn't say about miles but the engine had been rebuilt before.
I replaced them with the Supertec studs. It came down to a choice between 993 Turbo studs (fully threaded) or Supertec because the Raceware ones are silly money. Supertec ones fitted well, sensibly priced and came with good service so hopefully will do the job well. |
Just caught up with this build congrats on your work so far. If the engine is hard to start and runs rich it can be caused by the cylinder head temp sensor (CHT is screwed into Left foreward head) being out of range. The DME uses a resistance through the CHT to adjust the A/F ratios to enrichen for cold start. If defective it can cause the DME to adjust full rich at start and still very rich when warm and running. There is a ohm vs temp scale somewhere in the manual
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
ALEX P
Hi John,
You might well be right. I had another look at it last night and it starts fine on a cold engine and idles nicely. As soon as you touch the throttle it splutters and when there is some heat in the engine it won't idle until the rpm is held a lot higher. There is fuel coming from the exhaust and a bit of dark smoke due to it being so overfuelled. The engine only runs properly at around 2750rpm, presumably when it has the ability to burn off the excessive fuel being dumped in it. I know the ignition is fine and I've been through the vacuums and earths and I am pretty confident about them so I guess it could be alternator or ECU or most likely fuelling somewhere. The CHT makes a lot of sense so that it where I will start but I may chuck the car up to my specialist to do the checks as I don't really have the diagnostic equipment. Ideally I would want to check fuel pressure, co2 emmissions, injectors etc etc. One thing that I have been doing is disconnecting the battery at night. Someone suggested that sometimes thay need to run for 10 minutes or so as they can go into a panic mode when this is done but my money is still on fuelling somewhere. I'll report back Thanks |
Part # 930-606-013-02-m13 ? CHT sensor is only about $90 and quite easy to replace .I have seen it fail more than once and the engine runs dead rich with hard starting especially when warm. I would replace it without even testing it with your symptoms.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 08-16-2011 at 06:42 AM.. |
ALEX P
I've spoken to my local specialist today and he said that they change that sensor as a matter of course whenever they do a rebuild. Wish I knew that earlier!!
One thing I forgot to ask him - What do you think would happen if I disconnected the sensor when the car is warm? |
ALEX P
CHT sensor checks out
Hey John,
I took the CHT sensor off the car last night and checked it against the ohm v temp figures in the engine maintainance manual. Unfortunately it was all ok and the readings were spot on both at ambient and also when put next to a heat gun so the sensor itself is not the culprit. As these sensors cost around £100 over here, I can't find anything wrong with it and it's no big drama to fit/remove I'm going to put it back and check the ohm reading at ambient temp back at the connector onto the ECU on pins 30 and 45 as per manual to check the continuity between the sensor and the ECU. I'm a bit dissappointed that this doesn't appear to be the problem as it made perfect sense and it would have been a nice easy fix! Any other suggestions much appreciated. |
