should i swap my 1978 3.0 engine for a 1986 3.2?
should rebuilt my 3.0 or replace it with a3.2. it would cost me the same.
Old 02-02-2011, 08:50 PM
The 3.2, unless it has been sweetened up recently, will be just as rebuildable as the 3.0. Trading up to a used 3.2 is just changing the engine that needs rebuild. About 100k miles, the engines need work.
Bruce
Old 02-03-2011, 04:10 AM
brads911sc's Avatar
for about the same money you can turn it into a 3.2 SS.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-03-2011, 06:06 AM
Lots of variables to consider here; what is your 3.0 and what kind of shape is the 3.2 in? If your 3.0 has Mahle cylinders they can be reused most likely. That's a big chunk of the rebuild budget right there. If the 3.2 is in need of a rebuild also then I would stick with the 3.0 and spend the money on the rebuild of that rather than buy a 3.2 and then all the money needed for it's rebuild.
A 3.0 with some compression and cams can be a bunch of fun.
Lindy
Old 02-03-2011, 06:43 AM
the 3.0 has 3 broken head stud and 140,000 miles. i would need to rebuilt it
the 3.2 has been rebuilt has around 20,000 miles.
person it wanting $7000.for the 3.2 (1986}what else do i need to make that engine work on my 78.
Old 02-05-2011, 01:54 PM
WHAT would that cost ?and who do u know that would built it. what horse power would that have?
Old 02-05-2011, 01:55 PM
Lindy
1978 stock 3.0 has 3 broken head stud and 140,000 miles. i would need to rebuilt it
person is wanting $7000.{ is that to much}for the 3.2 (1986}what else do i need to make that engine work on my 78
Old 02-05-2011, 02:00 PM
If the 3.2 has receipts showing a quality rebuild, then it is a good deal. If you haven't seen it run, you should have a leakdown check performed.
-Andy
Old 02-05-2011, 06:53 PM
Laneco's Avatar
Do the swap. I'm mid-way through my 2nd 3.0 to 3.2 swap. It's a cool swap. Looks good, runs great, and even a monkey like me can do it. The worst you will do is go from 180 (3.0 stock) to 207 minimum (early 3.2's). You can drop a chip in, and an exhaust to make it run out REAL nice for the money.
Come on over to the dark side - we have horsepower and COOKIES!
angela
Hello
Old 02-08-2011, 01:36 AM
ALXinNZ's Avatar
3.2 no question. However If your car is an excellent original example I think the SC cars will start to climb in value so I would then rebuild the 3.0. Something to consider.
Old 02-12-2011, 10:09 PM
