should i swap my 1978 3.0 engine for a 1986 3.2?
should rebuilt my 3.0 or replace it with a3.2. it would cost me the same.
The 3.2, unless it has been sweetened up recently, will be just as rebuildable as the 3.0. Trading up to a used 3.2 is just changing the engine that needs rebuild. About 100k miles, the engines need work.
Bruce |
for about the same money you can turn it into a 3.2 SS.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Lots of variables to consider here; what is your 3.0 and what kind of shape is the 3.2 in? If your 3.0 has Mahle cylinders they can be reused most likely. That's a big chunk of the rebuild budget right there. If the 3.2 is in need of a rebuild also then I would stick with the 3.0 and spend the money on the rebuild of that rather than buy a 3.2 and then all the money needed for it's rebuild.
A 3.0 with some compression and cams can be a bunch of fun. Lindy |
the 3.0 has 3 broken head stud and 140,000 miles. i would need to rebuilt it
the 3.2 has been rebuilt has around 20,000 miles. person it wanting $7000.for the 3.2 (1986}what else do i need to make that engine work on my 78. |
WHAT would that cost ?and who do u know that would built it. what horse power would that have?
the 3.2 has been rebuilt has around 20,000 miles. person is wanting $7000.{ is that to much}for the 3.2 (1986}what else do i need to make that engine work on my 78 |
If the 3.2 has receipts showing a quality rebuild, then it is a good deal. If you haven't seen it run, you should have a leakdown check performed.
-Andy
72 Carrera RS replica, Spec 911 racer |
Do the swap. I'm mid-way through my 2nd 3.0 to 3.2 swap. It's a cool swap. Looks good, runs great, and even a monkey like me can do it. The worst you will do is go from 180 (3.0 stock) to 207 minimum (early 3.2's). You can drop a chip in, and an exhaust to make it run out REAL nice for the money.
Come on over to the dark side - we have horsepower and COOKIES! ![]() angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
3.2 no question. However If your car is an excellent original example I think the SC cars will start to climb in value so I would then rebuild the 3.0. Something to consider.
