neilca's Avatar
Piston Squirters
I have been searching and reading about piston squirters. Seems the turbo squirters have a hole that is 2mm.
Has anyone drilled out a standard set to make them flow like the turbo's?
Old 02-15-2011, 05:05 PM
tadd's Avatar
The 993tt squirters are 2 mm, but they are longer and stick way into the oil galley. I used them in my current build.
If I had to do it over, I'd see about using a pair of regular short 1 mm squirters like the latest RSR cases.
t
Old 02-16-2011, 07:59 AM
