anyone know how to remove snap ring
does any one know how to remove snap ring on the piston . i trying to use the snap ring remove but it is too short . anyone know what tool can remove it . thanx
snap ring pliers... or a small screw driver and a pair of needle nose pliers... craftsman makes snap ring pliers that have interchangable tips.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
i have to interchangable tip one but it seen too short to get the ring .
These are totally different fasteners requiring different tools and methods.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
it is snap ring in the piston , which hold the pin
The piston pins are usually off center of the piston. Its much easier to go to the side of the piston that the clip is closest to the outside and its also easiest to put it together that way. I have a couple ice pics that I use to get under the snap ring, circlip.
Bruce |
I use this small dental style pic. Work it under the circlip as shown. Then stick your finger in the wrist pin hole on the piston, work the clip out and catch it with your finger. Keeps them from flying all over the garage.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
The piece in the piston is not a snap ring. and as Steve said, the snap ring plier isnt going to work. I used a small screw driver and needle nose pliers. worked fine. For reinstall buy or borrow the Stomski tool. Youll have them all in in 5 minutes. Well worth it...
thanx guys
