Cleaning a magnesium crankcase
I'm fixing a 70 E engine that sat in a car in a barn for many years. Mice moved in, and their byproducts made a mess. Number 6 cylinder fins are very corroded, and the crankcase is kind of nasty looking, especially around nos. 5 and 6.
What is the best way for restoring the appearance? Media tumbling? Do I need to pull the head studs, first? Can anyone suggest a source in Massachusetts, southern NH or RI? Also, the oil in this engine was foul. Are the aqueous parts cleaners ok for magnesium? Last edited by Tom F2; 02-19-2011 at 11:40 AM.. |
Tom,
I would soda blast the case, followed by a thorough rinsing so you can closely inspect the areas of corrosion for any structural issues. Media tumbling does the best job of giving a finished appearance and you can coat it with Tectyl to prevent further corrosion. We use Ollie's in AZ for media tumbling these things.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Question.
Are there any differences in particle size. Or quality of them. Does is make a difference if the media has been "contaminated" with other metals. Or is a straight forward procedure? Like. Sir.... Can you please media blast my magnesium case and I will pick it up tomorrow? I'm trying to find a shop that can do this around here. I don't want to regret something that I didn't know. Thank you. |
You would ask them to soda blast. It is a one time use medium. It will not harm the magnesium while cleaning it. Other medium like glass bead etc. are too rough.
Ed 1973.5 T |
I assume you are going to get the case machined after it is cleaned, so the shop that does that, should be able to clean it for you.
Neil '73 911S targa |
Do not use any media other than soda. Glass bead will contaminate the oil passages and plug the piston squirters.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Are the aqueous parts cleaners safe, as a first step? I've used traditional parts cleaners (petroleum based) in the past, but this crankcase is filthy, and needs something more intense.
BTW, this crankcase has only 40,000 miles on it, and the no. 1 bearing shows no sign of distortion. So, I am not anticipating that there will be any machine work on the case.
My 2.7 looked like someone basted a 1000 turkeys on it. When it was on the engine stand I sprayed a few rusty nuts and bolts with PB blaster and noticed it cut through the grime most excellently. I cleaned up the real heavy stuff using a wood scraper, a liberal application of PB blaster and paper towels. After was mostly cleaned up I just used my parts washer for the final wash.
