-   -   911 T 2.2 rebuild - 1971 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/595821-911-t-2-2-rebuild-1971-a.html)
jbell959 12-06-2011 08:31 PM
I would check with Aaron Burnham at Rennworks. He goes by Burn-bros here on Pelican
ErrieKruger 12-09-2011 03:44 PM
Wiring elimination
It is amazing how much information this forum has accumulated over the years. There is nothing that was not covered at least a few times , by different Pelicans.
I learned in 2 days of searching that a few wires on the engine harness can be eliminated ( folded over and taped in ).
ErrieKruger 12-13-2011 05:32 PM
Distributor mailed to Aaron at Rennwerks today.
I got this thermostat with the engine , is it time specific and correct ?
http://forums.pelicanparts.com/uploa...1323826332.jpg
ErrieKruger 01-03-2012 06:15 AM
Bosch dizzy
Aaron at Rennwerks did a great job
http://forums.pelicanparts.com/uploa...1325600096.jpg
ErrieKruger 01-03-2012 06:55 AM
Test panel
I plan to run the engine on a test stand to look for oil leaks , set the timing , and make sure the Zeniths are set up correctly. Will also do oil changes every 5-10 min.
The Zeniths are a whole story on their own.
http://forums.pelicanparts.com/uploa...1325602123.jpg
ErrieKruger 01-06-2012 04:56 PM
Engine test stand
Pushing my luck in the living room again.
http://forums.pelicanparts.com/uploa...1325897645.jpg
ErrieKruger 01-06-2012 05:05 PM
The Scotts invented golf to frustrate people all over the world. Prof Ferdi used Zeniths.
http://forums.pelicanparts.com/uploa...1325897897.jpg
ErrieKruger 01-07-2012 05:41 PM
Test fitting Zeniths
http://forums.pelicanparts.com/uploa...1325986798.jpg
aleerpsoftware 01-11-2012 05:21 PM
wow....cool
ErrieKruger 01-12-2012 11:27 AM
Oil tank
Oil tank cleaned by radiator shop , rinsed with Seafoam and petrol , and then with alcohol. Cleaner on the inside than outside - needs a coat of paint.
http://forums.pelicanparts.com/uploa...1326396183.jpg
ErrieKruger 01-12-2012 03:12 PM
Pelican forums
Oil tank got a new coat.
I am sure the real stats are available , but my guess is that 95% of the readers of the Pelican forums are people like me. Always wanted to do this , but never had the opportunity or time. Or people that will get involved in a build one day.
Starting my build , I realized that it will not be easy , cost more that my worst case scenario , and be a positive learning experience.
This is a journey , not a destination - thanks Steve Tyler.
Most builds are done by amateurs in their free time. Many of those free hours used to drink a few cold ones just looking at the slow progress.
I am one of them , and love it.
http://forums.pelicanparts.com/uploa...1326408184.jpg
356RS 01-13-2012 12:45 PM
Great job. Can't wait to see it run on your test stand!
ErrieKruger 01-13-2012 09:54 PM
Test stand
Mark - NLA carburetor parts slowed my slow progress - Sir Tom Butler came to my rescue ( again ! )
Fuel supply lines
http://forums.pelicanparts.com/uploa...1326519896.jpg
Starter adapter that fits Porsche stand
http://forums.pelicanparts.com/uploa...1326519988.jpg
ErrieKruger 01-15-2012 03:11 PM
Starter adaptor
At my pace hope to have the engine running on the stand before the end of the Mayan calender.
http://forums.pelicanparts.com/uploa...1326668760.jpg
http://forums.pelicanparts.com/uploa...1326668855.jpg
ErrieKruger 02-19-2012 03:49 PM
Ordering parts
I am still alive and kicking , been waiting for 5 weeks for Zenith parts ordered by our host from Germany.:mad:
ErrieKruger 03-12-2012 06:52 PM
Zenith setup ????
http://forums.pelicanparts.com/uploa...1331603176.jpg
http://forums.pelicanparts.com/uploa...1331603254.jpg
http://forums.pelicanparts.com/uploa...1331603327.jpg
http://forums.pelicanparts.com/uploa...1331603379.jpg
Do I have Zenith and Weber parts mixed up here ?
jbell959 03-12-2012 07:36 PM
Weber and Zenith carbs use the same linkage. Looks like you have the right parts.. Hard to tell from the pictures what the problem is.
tom1394racing 03-13-2012 02:34 AM
Errie
Here are some pics of a Zenith setup in your area of concern. There is a very tight fit fit between the drop link and the accelerator pump linkage.
Hope this helps.
RHS
http://forums.pelicanparts.com/uploa...1331631077.jpg
http://forums.pelicanparts.com/uploa...1331631096.jpg
http://forums.pelicanparts.com/uploa...1331631114.jpg
http://forums.pelicanparts.com/uploa...1331631132.jpg
LHS
http://forums.pelicanparts.com/uploa...1331631158.jpg
NEWFIE 69 911E 03-13-2012 01:14 PM
Originally Posted by aleerpsoftware (Post 6488093)
wow....cool
VERY Cool - nice work :)
PrimeMvr 03-13-2012 01:18 PM
Comparing your pic to Tom's, it looks like this piece is on backward, but maybe it's just he camera angles.
http://forums.pelicanparts.com/uploa...1331669857.jpg
http://forums.pelicanparts.com/uploa...1331669867.jpg
