-   -   911 T 2.2 rebuild - 1971 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/595821-911-t-2-2-rebuild-1971-a.html)
jbell959 11-13-2011 07:17 PM
There is a longer oil line available for this. I may have an extra one if you need it.
jbell959 11-13-2011 07:41 PM
This is the part number for the correct oil line... but it's not cheap at $48
10-0224-107-M260
The other option, like on that previous picture is to use the hollow union bolt that is designed to go through the block that holds the pressure sender and find a sleeve (like in that picture) that fits the bolt. Then you can just use to standard sealing rings and you're set. That bolt is $15 or I'm sure people have these sitting around.
911-107-709-01
I'll take some pictures of the correct oil line and also the hollow bolt in the morning.
ErrieKruger 11-14-2011 05:31 AM
Jbell959 - You have a PM.
I have the hollow bolt , still too short. I will need a longer oil line , or an adapter like Flieger has on his line.
jbell959 11-14-2011 01:10 PM
Here is a picture of the standard oil line (top) with the hollow bolt connected to it. That hollow bolt goes through the block that holds the oil pressure sender.
The second line (bottom) is the longer line for use without the hollow bolt & sender block. For some reason these are sold without the ferrule and nut but they are available through Pelican or any parts house.
Another option, if you have a hose shop near by, is to have them replace the hose with a slightly longer one. I can measure the difference if you want to do that.
http://forums.pelicanparts.com/uploa...1321308614.jpg
Flieger 11-14-2011 03:40 PM
Someone with a lathe and some hex Aluminum or brass ought to be able to whip out an adapter right quick.
ErrieKruger 11-14-2011 08:27 PM
I ordered another through bolt from our host - the one in the pic above is way longer than the one I have. Looks about size.
Thanks for your help!
ErrieKruger 11-19-2011 06:52 PM
Nothing comes easy
One header slipped on , the other one is totally misaligned. Bending the pipe in does not help , as the holes still does not line up with the studs.
http://forums.pelicanparts.com/uploa...1321760669.jpg
http://forums.pelicanparts.com/uploa...1321760752.jpg
jbell959 11-19-2011 07:06 PM
I had the same problem with a set I had. I ended up spending a couple hours heating and bending the pipes before finally getting it to fit.
ErrieKruger 11-20-2011 08:46 PM
Marelli distributor
New rotor for Marelli ordered from the UK. Will have to see if it fits. I have a Bosch dizzy on standby , but it needs some work.
http://forums.pelicanparts.com/uploa...1321854032.jpg
ErrieKruger 11-22-2011 07:52 PM
http://forums.pelicanparts.com/uploa...1322023893.jpg
ErrieKruger 11-24-2011 09:28 PM
Starting to put the harness back on .
What is this called , and what is it's function ?
http://forums.pelicanparts.com/uploa...1322202290.jpg
Flieger 11-24-2011 10:24 PM
That is the microswitch that activates the speed switch to turn off the fuel when you are engine braking above about 1500 rpm. It is just one link in the system so having it installed may or may not result in the system functioning properly.
The RPM transducer is commonly broken or missing. It is usually just some broken wire leads on a couple transistors. I repaired mine but I had an oscilloscope and function generator in the garage and my Dad is an EE. The MFI and carburetor versions are different.
The RPM transducer is in a silver box on the engine electrical panel. It receives 12V power and a signal from the distributor so that it knows what RPM the engine is turning at. Based on that info, the Speed Switch will decide when to send 12V to the microswitch. When the microswitch has 12V to its leads and the throttle is closed, the throttle arm hits the microswitch and closes the circuit, allowing the 12V to flow to the shut-off solenoid which pushes the MFI pump rack to a position that stops fuel from being dispensed from the injectors (not enough pressure to open the pintles I guess, maybe not full shut off). When the RPM drops below 1300 rpm with the throttle closed the RPM transducer will quit sending 12V so the solenoid releases and the engine gets more fuel. It then picks up speed to 1500RPM and the process repeats until you are back on the gas.
Not sure exactly how the carb version works.
piggdekk 11-24-2011 10:39 PM
It's the carburator's idle switch. It is used to activate the enrichment circuit of the Zenith's. If You've plugged the enrichment circuit You can leave it out.
luca
piggdekk 11-24-2011 10:42 PM
Fliger, we've posted at the same time.
On the carburators there is a solenoid that opens the circuit and allows more fuel/air if the throtthe is depressed (switch activated) and the rev's are above 1300. Below that the solenoid should close.
luca
ErrieKruger 11-25-2011 06:39 AM
Prof Max - thanks !
To my understanding I can therefore eliminate this ? I will plug the enrichment on the Zeniths as Luca proposed.
Flieger 11-25-2011 09:56 AM
I would go with what piggdekk says since I am not familiar with carbs.
Now that I think about it there is no way you can shut fuel off to carbs. Just to the bowls.
I guess Porsche repurposed the microswitch.
piggdekk 11-25-2011 08:15 PM
yes if You plug the enrichment there is no reason to keep the switch, the solenoid and the RPM transducer.
ErrieKruger 12-05-2011 04:21 PM
It took time , heat , and other support , to get these fitted.
http://forums.pelicanparts.com/uploa...1323134284.jpg
ErrieKruger 12-06-2011 04:20 PM
Elecrical connections
I will plug the enrichment system on the Zeniths , and need conformation to decide which and how to eliminate unwanted wires.
http://forums.pelicanparts.com/uploa...1323220291.jpg
http://forums.pelicanparts.com/uploa...1323220380.jpg
http://forums.pelicanparts.com/uploa...1323220469.jpg
http://forums.pelicanparts.com/uploa...1323220591.jpg
http://forums.pelicanparts.com/uploa...1323220665.jpg
ErrieKruger 12-06-2011 04:38 PM
Bosch 0 231 184 001
Who should I trust to make a Bosch 0 231 184 001 dizzy compatible with my 1971 2.2 ( now 2.3 ) engine ? The shaft needs to be machined to fit.
jbell959 12-06-2011 07:31 PM
I would check with Aaron Burnham at Rennworks. He goes by Burn-bros here on Pelican
ErrieKruger 12-09-2011 02:44 PM
Wiring elimination
It is amazing how much information this forum has accumulated over the years. There is nothing that was not covered at least a few times , by different Pelicans.
I learned in 2 days of searching that a few wires on the engine harness can be eliminated ( folded over and taped in ).
ErrieKruger 12-13-2011 04:32 PM
Distributor mailed to Aaron at Rennwerks today.
I got this thermostat with the engine , is it time specific and correct ?
http://forums.pelicanparts.com/uploa...1323826332.jpg
ErrieKruger 01-03-2012 05:15 AM
Bosch dizzy
Aaron at Rennwerks did a great job
http://forums.pelicanparts.com/uploa...1325600096.jpg
ErrieKruger 01-03-2012 05:55 AM
Test panel
I plan to run the engine on a test stand to look for oil leaks , set the timing , and make sure the Zeniths are set up correctly. Will also do oil changes every 5-10 min.
The Zeniths are a whole story on their own.
http://forums.pelicanparts.com/uploa...1325602123.jpg
ErrieKruger 01-06-2012 03:56 PM
Engine test stand
Pushing my luck in the living room again.
http://forums.pelicanparts.com/uploa...1325897645.jpg
ErrieKruger 01-06-2012 04:05 PM
The Scotts invented golf to frustrate people all over the world. Prof Ferdi used Zeniths.
http://forums.pelicanparts.com/uploa...1325897897.jpg
ErrieKruger 01-07-2012 04:41 PM
Test fitting Zeniths
http://forums.pelicanparts.com/uploa...1325986798.jpg
aleerpsoftware 01-11-2012 04:21 PM
wow....cool
ErrieKruger 01-12-2012 10:27 AM
Oil tank
Oil tank cleaned by radiator shop , rinsed with Seafoam and petrol , and then with alcohol. Cleaner on the inside than outside - needs a coat of paint.
http://forums.pelicanparts.com/uploa...1326396183.jpg
ErrieKruger 01-12-2012 02:12 PM
Pelican forums
Oil tank got a new coat.
I am sure the real stats are available , but my guess is that 95% of the readers of the Pelican forums are people like me. Always wanted to do this , but never had the opportunity or time. Or people that will get involved in a build one day.
Starting my build , I realized that it will not be easy , cost more that my worst case scenario , and be a positive learning experience.
This is a journey , not a destination - thanks Steve Tyler.
Most builds are done by amateurs in their free time. Many of those free hours used to drink a few cold ones just looking at the slow progress.
I am one of them , and love it.
http://forums.pelicanparts.com/uploa...1326408184.jpg
356RS 01-13-2012 11:45 AM
Great job. Can't wait to see it run on your test stand!
ErrieKruger 01-13-2012 08:54 PM
Test stand
Mark - NLA carburetor parts slowed my slow progress - Sir Tom Butler came to my rescue ( again ! )
Fuel supply lines
http://forums.pelicanparts.com/uploa...1326519896.jpg
Starter adapter that fits Porsche stand
http://forums.pelicanparts.com/uploa...1326519988.jpg
ErrieKruger 01-15-2012 02:11 PM
Starter adaptor
At my pace hope to have the engine running on the stand before the end of the Mayan calender.
http://forums.pelicanparts.com/uploa...1326668760.jpg
http://forums.pelicanparts.com/uploa...1326668855.jpg
ErrieKruger 02-19-2012 02:49 PM
Ordering parts
I am still alive and kicking , been waiting for 5 weeks for Zenith parts ordered by our host from Germany.:mad:
ErrieKruger 03-12-2012 05:52 PM
Zenith setup ????
http://forums.pelicanparts.com/uploa...1331603176.jpg
http://forums.pelicanparts.com/uploa...1331603254.jpg
http://forums.pelicanparts.com/uploa...1331603327.jpg
http://forums.pelicanparts.com/uploa...1331603379.jpg
Do I have Zenith and Weber parts mixed up here ?
jbell959 03-12-2012 06:36 PM
Weber and Zenith carbs use the same linkage. Looks like you have the right parts.. Hard to tell from the pictures what the problem is.
tom1394racing 03-13-2012 01:34 AM
Errie
Here are some pics of a Zenith setup in your area of concern. There is a very tight fit fit between the drop link and the accelerator pump linkage.
Hope this helps.
RHS
http://forums.pelicanparts.com/uploa...1331631077.jpg
http://forums.pelicanparts.com/uploa...1331631096.jpg
http://forums.pelicanparts.com/uploa...1331631114.jpg
http://forums.pelicanparts.com/uploa...1331631132.jpg
LHS
http://forums.pelicanparts.com/uploa...1331631158.jpg
NEWFIE 69 911E 03-13-2012 12:14 PM
Originally Posted by aleerpsoftware (Post 6488093)
wow....cool
VERY Cool - nice work :)
PrimeMvr 03-13-2012 12:18 PM
Comparing your pic to Tom's, it looks like this piece is on backward, but maybe it's just he camera angles.
http://forums.pelicanparts.com/uploa...1331669857.jpg
http://forums.pelicanparts.com/uploa...1331669867.jpg
