Tolerances for boring barrels
Hi all,
I'm planning on having some 80.0mm 2 litre barrels from a 67 911 bored out to 81.5mm.
Does anyone know the tolerances I should provide to the machinist?
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 10-21-2015, 07:53 PM
Clearances depend on what pistons you will use,... .
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-22-2015, 12:22 AM
Thanks Steve - pistons are 9.8:1 JE's.
Cheers, Ryan
Old 10-22-2015, 01:31 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Bore to 81.47mm and hone to the desired tolerance. If 81.5mm if the pistons are perfect. We like to size each piston.
All piston manufacturers build their desired clearance into the piston.
If everything was exact you would bore to 81.5mm. Then the JE would fit perfectly but nothing is exact. Each piston and each cylinder will have a tolerance. If your machinist can hold a .0005 that's about as good as you could hope for.
JE uses a .0015-0025" depending on the diameter and cylinder material.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-22-2015, 04:25 AM
Thanks Henry, much appreciated.
Cheers, Ryan
Old 10-22-2015, 04:01 PM
What's the opinion on clearance for Mahle forged pistons? 80.5mm diameter.
andy
Old 10-22-2015, 10:31 PM
304065's Avatar
Of course you must measure.
Jugs and Slugs: Confessions of a JE Piston owner
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-23-2015, 06:37 PM
