Question on dual plugging EDIS ignition
I need to consider dual plugging. Doesn't appear to take a lot with EDIS already in place. But uncertain as how to configure such as system. Run 2 EDIS modules off one VR sensor ?
I guess I would need different lower covers. How to protect plug wires from road grid, salt water and debris ?
80SC (ex California)
Old 03-19-2011, 12:42 PM
Works fine with one VR sensor. I have 964 upper and lower covers on mine. I drilled the 6mm holes to 8mm or modify stock lower covers.
Old 03-19-2011, 11:15 PM
sjf911's Avatar
I ran parallel EDIS controllers in a twin plug setup for quite a while. It works very well. You split the VR signal to both EDIS controllers but only need to wire a single PIP signal from one controller to MS and then split the SAW output from the MS ECU to both EDIS controllers.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-20-2011, 08:04 AM
Excellent.
Then I need only to find someone to machine the heads. I'll see if I can get away with running the sparkplugs leads under the covers
Old 03-20-2011, 08:39 AM
