Cam removal problem, 1982 911 SC 3.0
Hey to all,
Removed the cam sprockets and cannot get the woodruff keys out. Wayne's book indicates to "pry them out" using a small screwdriver, I cannot get them to budge. Any hints? Cross posting in 911 Technical forum Thanks if anyone can help, stalled out on an already painfully slow project. Darwin |
Put a small screwdriver under the leading edge of the key, tap with a hammer to have the key roll out. Then use pliers to finish pulling out
It’s even more fun putting them in..... Bruce |
OK, thanks. Will try it tomorrow. Going to drink scotch tonight instead of working on the engine. Are the keys just standard issue when replacing or are they made of unobtainium and priced in the stratosphere.
Google 911 cam timing woodruff key. They might sell them here.
Our host sells them. They're cheap
+1 The only way to get them out. Make sure you blocked the cam housing opening to prevent the key from dropping in the engine case. |
Member 911 Anonymous
+1
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Side cutters work too, but the screwdriver method above should have them out with no damage. Block the chain housing holes where the chains come out, if your not stripping the full engine down. I normally take all the rockers out at tdc on each cylinder first
