-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
rsrfan 04-24-2013 03:38 PM
It will be harsh, but not rattle your teeth out harsh. You will need to do something to counteract the squat that will occur when you put that much power down. In addition to the 30s, you may need helper springs...
CaptainCalf 04-24-2013 03:59 PM
That what I was thinking...What do helper springs look like?
rsrfan 04-25-2013 08:56 AM
You have to go to a coil over set up on the back. Cheapest is a a Rebel or Elephant sleeve kit for your existing bilsteins. Usually you want to run around 150-200 pound springs in addition to the torsion bars depending upon their size... Clint or Chuck will be able to set you up.
CaptainCalf 04-25-2013 09:33 AM
Thanks, I had no idea they made sleeve kitsSmileWavy
CaptainCalf 04-28-2013 05:23 AM
OEM fuel pump vs 044
The 044 pump is nearly twice the size of the OEM front pump.
http://forums.pelicanparts.com/uploa...1367155406.jpg
JFairman 04-28-2013 06:28 AM
When I took out the front fuel pump in my '87 turbo and replaced it with a new 044 pump they were both the same thickness but the 044 was about 3/4" longer like yours appears.
You can remove the spacer between the check valve and pump. That shortens the overall length and it fits in the origonal position better.
Porsche also makes a thick rubber sleave with rubber cap that goes on the end that fits the 044 like a glove and quiets it down alot. I think it was origonal equipment on the 964 and 993. Maybe other's had it too.
With the rubber sleave the pump won't fit in the origonal pump mount but you can remove the origonal mount and push the rubber sleaved pump up in between the front cross member and the gas tank and secure it there with a long american made hose clamp.
The origonal banjo fitting fuel line still fits with it mounted like that. You may have to lengthen the wires a little and you wil have to put larger eyelets on the ends to fit over the thicker wire terminal studs on the 044.
CaptainCalf 04-28-2013 06:55 AM
When I took out the front fuel pump in my '87 turbo and replaced it with a new 044 pump they were both the same thickness but the 044 was about 3/4" longer like yours appears.<br>
<br>
You can remove the spacer between the check valve and pump. That shortens the overall length and it fits in the origonal position better. <br>
Porsche also makes a thick rubber sleave with rubber cap that goes on the end that fits the 044 like a glove and quiets it down alot. I think it was origonal equipment on the 964 and 993. Maybe other's had it too.<br>
<br>
With the rubber sleave the pump won't fit in the origonal pump mount but you can remove the origonal mount and push the rubber sleaved pump up in between the front cross member and the gas tank and secure it there with a long american made hose clamp. <br>
I shortened the rubber hose a little between the tank and pump and it fit fine. Found a busted rubber isolator mount so replaced that and I had to use a larger clamp, but all in all it was a nice fit. Under high boost it makes AFRs in the 11s now, so all is good with fueling now...
PFM 04-28-2013 08:26 AM
Captain,
How on earth did you get to test "under high boost"? Might it be some spirited driving?
Enjoy the fruits of your labors....
CaptainCalf 04-28-2013 08:40 AM
Captain,<br>
<br>
How on earth did you get to test "under high boost"? Might it be some spirited driving? <br>
<br>
LOL, can't find a road long enough for 4th gear but boosting 3rd is scary fast...thanks!
CaptainCalf 05-07-2013 11:16 AM
Drove to work today
It was fun putting this puzzle together, but I think driving it is more fun:D
http://forums.pelicanparts.com/uploa...1367954089.jpg
My shady spot at work
http://forums.pelicanparts.com/uploa...1367954103.jpg
Not much shade at the gym
jsveb 05-07-2013 11:40 AM
Looks fantastic.
CaptainCalf 05-07-2013 11:42 AM
Originally Posted by jsveb (Post 7428206)
Looks fantastic.
ThanksSmileWavy
I'll have to rub all the love bugs off it when I get home tonight, but it should only take a couple of beers;)
CaptainCalf 02-27-2014 11:10 AM
Clutch Falure
After putting about 6,000 easy non-race miles on this new clutch an inner piece broke off and decide to come out. Luckily it bound up the motor on start up and was addressed before it cause any major damage. I've asked the folks I bought it from if they'd replace it as defective since it hasn't been mistreated and still looks new.
http://forums.pelicanparts.com/uploa...1393531742.jpg
http://forums.pelicanparts.com/uploa...1393531763.jpg
http://forums.pelicanparts.com/uploa...1393531773.jpg
What do you guys think? Does it look defective to y'all?
sjf911 02-27-2014 11:16 AM
Wow, that has to be a manufacturing flaw. Let me know if they won't take it back and you're going to junk it, I'm looking for a worn out disc to make a transmission locking tool.
CaptainCalf 02-27-2014 11:18 AM
Will doSmileWavy
PrimeMvr 02-27-2014 01:03 PM
Sure looks like a defect to me. Curious...are you able to get the trans out without dropping the engine on one of these things? I've always dropped them together, but going through all the disconnects if you only needed to do a clutch stinks.
CaptainCalf 02-27-2014 01:07 PM
Yep, gotta drop it...labor of love for most good 930 mechanics.
CaptainCalf 03-31-2014 10:11 AM
New clutch, corner balance and alignment all done...Thanks to Micky at European Performance!
I'll miss this one very much, but we gotta sell it cuz we're moving from the burbs into the city so we're loosing our big 3 car garage...:(
I'll post it up for sale offically tomorrow here on Pelican and in the other usual locations, but if anybody here who's watching this thread is interested please shoot me a PM & thanks for everything...it's been a great ride!SmileWavy
RC
CaptainCalf 04-03-2014 06:31 AM
http://forums.pelicanparts.com/porsche-cars-sale/804292-fs-1987-930-lithia-fl.html
ChrisP911 11-11-2014 10:09 AM
What was the final HP after you installed the 044 fuel pump
CaptainCalf 11-11-2014 10:15 AM
My tuner guesses 500 at the crank at 0.8 bar, but we still need to put it on the dyno to tune the high boost level at 1.2, so I think we can easily surpass 500 at the wheels...
ChrisP911 11-12-2014 11:05 AM
wow that is awesome congrats
