Save yourself the trip, I'll use it as an excuse to come by and see everything in person, lol.
Das roll bars
Anybody got a set of these laying around that they wanna get outta the garage
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Sound/heat barrier installed
i decided to install a nice layer of heat/sound protection before installing new carpet
headliner is going in
Installing the headliner is a slow process for me, but it may just turn out looking good if I don't cut it too short
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 12-07-2011 at 08:22 PM.. Reason: spell |
Rennline pedal kit installed
amazing what a little bit of bling can do
Das Roll Bar
FedEx delivered my new roll bar today and surprisingly it fits in my car, so off the powder coater
sunroof sound/vibration baffles
The 2 original baffles between the headliner and the sunroof motor are toast. The fiber boards are moisture damaged and the foam is falling apart.
Ordered 2 new ones from our host and was told they are not available from anywhere, so I'm making my own outta aluminum and bio foam that will be moisture proof! ![]() ![]() ![]() ![]() ![]() ![]() ![]()
New Window Gaskets
While waiting for injectors, sensors and wire harness before I can fire up the motor I'm still working on an interior refresh and I gotta say that no matter what folks charge to install new window gaskets it's not enough!
I used soapy water which helped a little, but to get the trim in I had to use some 100% silicone grease. 1 window down and 3 to go ![]()
Metric Fuel Line Fittings
After searching the internet for metric fittings I found a distributor in my own back yard
![]() If you ever need something like M16x1.5 to -6AN fittings check these guys out: BAT, Inc in Sarasota, FL 941.355.0005.
Old rubber is the worst, especially when the ambient temps are not too hot.
Front window was replaced along with the gasket back in the early 2000's so that one will hopefully not be as bad as the others. If they give you trouble put them in an oven set around 100 degrees. When you go to pop them in that way the rubber will be much more compliant when you do. |
defroster vent cover
Anybody know why this thing is painted brown? I think I'll paint it brown again unless it should be black?
Perhaps it faded to where it appears brown?
Maybe because the car had brown interieur from factory
Roland 930 Turbo '81 Too many modifications to list |
After ripping out what seemed like 25 year old black carpet and headliner I'm pretty sure the original factory color was black w/o looking it up, so looks like the defroster vent cover faded to look brown...I'll paint it black again.
Strut Tower Brace
New strut tower brace came in today thanks to our host
strut brace
strut brace done
uphostery
recovered the rear side window trim bars since they will be needed to finish off the RS carpeting
Roll bars and bell crank bushings
Pressed in the new tranny bell crank bushings and picked up the freshly powder coated satin black roll bars. Now I just need to find time to finish the interior before the rest of the engine parts get here
