gtc gtc is offline
abides.
gtc's Avatar
Shop time to install/set valve springs?
Can someone give me a rough estimate of how long it should take a shop to replace the stock valve springs and retainers on my freshly rebuilt heads with some performance springs and Ti retainers?
I'm nearing the end of my rebuild and the budget is wearing thin, as often happens I suppose.
Graham
1984 Carrera Targa
Old 11-06-2014, 10:37 AM
abit off center
cgarr's Avatar
Less than an hour, got all the parts and specs?
______________________
Craig
G2Performance
Old 11-06-2014, 06:42 PM
gtc gtc is offline
abides.
gtc's Avatar
Thanks.
Yep, have evertything ready to go. Too bad I didn't think about it before you did the heads for me :/
Graham
1984 Carrera Targa
Old 11-07-2014, 09:06 AM
Jeff Alton's Avatar
An hour gives the tech 5 mins per spring to set remove, set height and install. Sounds about right....
www.turn3autosport.com
Old 11-09-2014, 07:33 PM
If you have a good valve spring compressor you can do it yourself, it's not difficult.
Valve spring hight is important and that's adjusted with how many shims are stacked up under the spring seat. Usually around 7 shims depending how deep the valve seats are.
I saved this picture of a tool someone made and posted for setting spring hight to 34.5mm.
Old 11-09-2014, 08:25 PM
abit off center
cgarr's Avatar
Hey as long as we are showing off our tool why not:
Craig
G2Performance
Old 11-11-2014, 06:48 PM
