Rocker Seal Installation procedure
Yes, I have done my search but I have not found a step by set guide on performing the installation.
Going to check my books now...
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 05-05-2011, 12:35 PM
All I ever did was use a miniture screwdriver, slip the seal on to the shaft and slip the small screwdriver under the seal and rotate the s driver around the shaft until the seal drops into the groove.
Bruce
Old 05-05-2011, 01:21 PM
Thanks, I think I got it.
Is it possible to do #1 and #4 on the top while the chain housings are in place?
Jeremy C.
-2001 996 Turbo
Old 05-05-2011, 01:58 PM
You just have to push it out the other way, thats why the 5mm hex is to the inside of the cam carrier.
Bruce
Old 05-05-2011, 07:22 PM
Thanks.
So for the other ones, I have been tapping them through to the 8mm side. Does it matter which way they come out and go back in?
I have been keeping it teh same, so when I would pull it out on the 8mm side, I would put it back in though that side.
Jeremy C.
-2001 996 Turbo
Old 05-06-2011, 06:26 AM
