txhokie4life's Avatar
All cranks use same bearings?
I acquired an RSR replica which has a 3.8L engine.
The engine appears to have spun a bearing and I'm doing some
preliminary homework on my options.
I know my M96 engines, this is my first aircooled foray.
From reading -- All things being equal the preferred crankshaft is a GT3 form a 997.
Do all the crankshafts 964/993/GT3 use the same bearings?
As ironic as this may sound -- I'm trying to be cost sensitive and
it would not make much sense to save $50 on a crankshaft only
to lock me into bearings that are super exclusive and cost me a small fortune.
Hope to crack the case this weekend and dive in.
thanks for you help,
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 05-11-2011, 07:27 AM
bearings
The mains are the same, all three rod brg.s are different.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-11-2011, 07:32 AM
Well it turns out there aren't any new 997 GT3 cranks available.
On back order -- could be months!
Recommended Alternatives?
m
2001 996 GT2
Old 05-11-2011, 08:33 AM
