MJR MJR is offline
3.3 Turbo Mystery Part...
Tore down the engine and found these 0.5mm shims between the cylinder and head. Not a fire ring, and I see no benefit other than lowering compression and brinneling the aluminum (sarcasm)...
Wondering if someone's seen them before, and what the possible purpose could be if it's an actual aftermarket part and not someones back-woods engineering development program.
FWIW, the head to cylinder interface depth, and cylinder deck height check out to stock, so there's been no machining.
Thanks,
Matt
Old 05-20-2011, 03:11 AM
Hi I have them on mine as the heads were cut that amount.
Old 05-20-2011, 04:14 AM
MJR MJR is offline
Thanks for that. Do you know who makes them?
This motor is untouched (machine work wise), which is why I can't find any reason for them
Old 05-20-2011, 04:49 AM
Certified User
billjam's Avatar
If your turbo is a 91-ish model, they are standard head gaskets.
If you need a set, PM me. I bought a set by mistake. Got my part numbers mixed up
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 05-20-2011, 05:05 AM
mine came from ollies when the heads were cut hope that helps
Old 05-20-2011, 02:01 PM
MJR MJR is offline
Car's an '89, so there should be no gasket. The motor's been apart before, so maybe the rebuilder installed the later head gaskets...
Old 05-20-2011, 04:41 PM
Racer
winders's Avatar
If it is an '89 motor and there is a recess in the heads for the gasket in the heads, and you have gaskets, why are you wondering what the gaskets are for? There would be no recess for the gasket if the heads were untouched '89 heads...
Wait...is this for an '89 Turbo motor? I know the '89 3.6 Liter didn't have head gaskets....I don't know about an '89 Turbo 3.3 Liter.
Scott
Old 05-20-2011, 06:17 PM
MJR MJR is offline
'89 930 turbo motor. Book says it's not supposed to have anything in there.
My initial post is a little misleading, I think. My question should be: "Am I missing something here?"
I build high performance and race engines for Japanese and American cars, but this is the first Porsche 911 engine I've ever been inside
Also, these "gaskets" are .5mm stainless steel shims, which doesn't qualify them as a gasket. They wouldn't contribute anything to sealing, that I can see.
Cheers,
Matt
On a side note: several different hacks have been inside this motor. You wouldn't believe the things I've found... Four of six pistons with the pin offset in the wrong direction, sealed with Indian Head gasket shelack, silicone gooped all over everything, exhaust studs that were broken and drilled between the stud and aluminum for a 6mm bolt, these shims, cracked injector housings that were gooped over with epoxy, silicone and god knows what, centered rocker shafts.
Three broken dilivar studs, one of which was a 993 stud... Someone took it apart before and replaced only three broken head studs with 993 dilivar... They left the rest, and now two more original ones and one of the 993's is broken.
Pelican Parts is lovin' it!
Old 05-20-2011, 07:24 PM
abit off center
cgarr's Avatar
If you have a big mic you can see if the heads have been surfaced a lot thus the need for the shims. Head should be 84.5mm from the top cam surface to the sealing surface and the max cut head would be 84.25mm
______________________
Craig
G2Performance
Old 05-20-2011, 07:45 PM
MJR MJR is offline
Pretty dang close.
Old 05-21-2011, 12:46 AM
Manassas, VA
lucittm's Avatar
My 1991 Turbo has those sealing rings. I replaced three of them with identical parts from our host when I did a one side rebuild. Are your heads stock? What is the date casting? 1989 may have been a cut-over for the head sealing ring for the Turbo. Consider yourself upgraded, that was the state of the art in 1991-1992.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 05-25-2011, 05:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The head gasket application is more a function of appropriate cylinder than the head unless the head was modified.
If your cylinders have full fills and measure 97mm they are in fact 91-92 C2 Turbo cylinders and they were designed to used with head sealing gaskets.
If you cylinders have partial fins and measure 97mm they a 78-89 turbo cylinders and were designed to function without sealing gaskets.
The gaskets in your picture are indeed 91-92 C2 Turbo sealing rings.
What we are talking about here is basically a dimensioning question.
If you install the gaskets will your engine produce the compression you a looking for? To answer that question you must perform a simple compression calculation.
Good luck
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-26-2011, 08:47 AM
MJR MJR is offline
Good luck
I can't believe I didn't think of the compression... So flustered, I guess...
Anyway, the engine is an '89 3.3 for sure. Cylinder fins on the lower half only, no base o-rings, and the sealing surface on the deck is 113mm dia.
Quick down-and-dirty compression ratio check shows 6.75 with and 6.97 without the rings. So, toss 'em it is.
Thanks Henry and everyone else.
Old 05-26-2011, 07:52 PM
