GaryR's Avatar
Send a message via ICQ to GaryR
Is this glue on the back ot the cam chain boxes?
Looks like a sealant of some type to keep oil from coming through from the chain rail pins and the tensioner pivot.
Can I just remove it, clean it up, and cover the area with some fresh JB Weld or is there something better?
Thanks.
Gary R.
Old 07-10-2011, 02:06 PM
Looks like the epoxy that the factory uses to cover the back of non-threaded plugs. Helps hold it it place and seals against oil leaks. Scrap off the rest of it with a wire brush and use some JB Weld to replace it.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-10-2011, 03:35 PM
GaryR's Avatar
Thank you Rob, will do.
Gary R.
Old 07-10-2011, 04:07 PM
Drive it like u stole it.
jonesb930's Avatar
+1 what Rob said. I believe this is covered in Waynes book. Pick up a copy if you havent got one already.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 07-10-2011, 06:32 PM
