Changing cams
I have a 2.4T CIS motor that I changed to carbs. Can I simply swap out the CIS cams for E or S cams keeping the CIS pistons?
Kev
Old 07-19-2011, 09:31 PM
Nossir,..those other cams have much more valve lift and the intake valves will strike the CIS piston domes.
You need to install E or S pistons to accomodate a cam change like that.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-19-2011, 10:37 PM
BURN-BROS's Avatar
Hi Kev,
About the best you can do is a 20/21 or equivalent from DR racing cams.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-21-2011, 08:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You can pocket the CIS pistons to allow for the installation of more aggressive cams. This lowers the compression slightly but the increase in performance far exceeds the performance loss from the compression reduction.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-21-2011, 08:26 AM
