Location: Vilnius Lithuania (it's in Europe and it's not Russia)
2 questions rebuilding 3,3 turbo engine
hi, I am rebuilding my 86 3,3 turbo engine and
1. I am not sure about crankcase through bolt tightening. I have tightened them to factory spec, but due to rubber O-rings these bolts do not fit tight(you can easily turn entire bolt turning nut at one end). 2. should I use OEM cylinder head washers, if I am using arp head studs and nuts? |
You need to torque the cross bolts more than one time.
Bruce |
I did, by the way I even torqued 10nm more than it is recommended by factory, but still they look to me too loose.
Must be the green O rings, I only used them once and wont fool with them again. I think if you use the proper concave washers all will be OK.
Bruce |
Sounds strange that you could hit factory torque specs and still have them be less than tight. Are you sure you have the right o- rings?
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
used blue o-rings that came in victor reinz crankcase gasket set.
