67s engine series
Hello, does anyone have a data base for S engines for 67. I have 901/05 909118
and I was wondering where it came from. Thanks
67' tangerine targa |
from late 66 for the 67 model year. Dave P has a database but yours is most certainly not an S engine. Additionally S engines for the 67 model year start with with serial number '96' andy |
about yours engine
Hello,
Here detailed information about yours engine. As you have told this engine is not s-engine. Modelljahr Modell Motor PS bei U/min Nm bei U/min Fahrgestellnummern Motornummern Stückzahl Bemerkungen 1967 911 Coupe 901/05 130/6100 174/4200 305101-307350 907001-909000 3421 03/66 Weber-Vergaser 911 S Coupe 901/02 160/6600 179/5200 305101S-308523S 960001-961178 wie 911 ab 10/66 911 S Targa 901/02 160/6600 179/5200 500001-500718S 960001-961178 wie 911 targa ab 12/66 Last edited by wtch; 08-06-2011 at 01:24 AM.. Reason: more info |
Thank you
Thanks for your quick replies. Would using this coupe 67 engine in a targa 67 reduce its value?
The is no coupe engine. The engines could be used in either coupe or targa.
An S engine installed in a car determined if the VIN was amended with an S or not. 909118 is not an S engine, but it is an early 1967 MY engine type 901/05. Unfortunately, the Targa production was delayed, and I believe they all got the type 901/06 engine with the 911xxx serial range as did all the later 1967 coupes. So that is not the correct engine type for your targa, and certainly not the original engine.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
about so called Targa engine
Targas had these.. 911 Targa 901/05 130/6100 174/4200 500001-500718 911191-912050 |
