67targa's Avatar
Send a message via Yahoo to 67targa
67s engine series
Hello, does anyone have a data base for S engines for 67. I have 901/05 909118
and I was wondering where it came from. Thanks
67' tangerine targa
Old 08-05-2011, 05:33 PM
A 67S engine will be 901/02. You have a 67 normal engine there. Most likely
from late 66 for the 67 model year. Dave P has a database but yours is most
certainly not an S engine. Additionally S engines for the 67 model year start
with with serial number '96'
andy
Old 08-05-2011, 09:06 PM
about yours engine
Hello,
Here detailed information about yours engine.
As you have told this engine is not s-engine.
Modelljahr Modell Motor PS bei U/min Nm bei U/min Fahrgestellnummern Motornummern Stückzahl Bemerkungen
1967 911 Coupe 901/05 130/6100 174/4200 305101-307350 907001-909000 3421 03/66 Weber-Vergaser
911 S Coupe 901/02 160/6600 179/5200 305101S-308523S 960001-961178 wie 911 ab 10/66
911 S Targa 901/02 160/6600 179/5200 500001-500718S 960001-961178 wie 911 targa ab 12/66
Old 08-06-2011, 01:10 AM
67targa's Avatar
Thank you
Thanks for your quick replies. Would using this coupe 67 engine in a targa 67 reduce its value?
67' tangerine targa
Old 08-06-2011, 01:54 PM
djpateman's Avatar
The is no coupe engine. The engines could be used in either coupe or targa.
An S engine installed in a car determined if the VIN was amended with an S or not.
909118 is not an S engine, but it is an early 1967 MY engine type 901/05. Unfortunately, the Targa production was delayed, and I believe they all got the type 901/06 engine with the 911xxx serial range as did all the later 1967 coupes. So that is not the correct engine type for your targa, and certainly not the original engine.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-08-2011, 09:38 AM
about so called Targa engine
Targas had these..
911 Targa 901/05 130/6100 174/4200 500001-500718 911191-912050
Old 08-08-2011, 11:05 AM
