Pressure fed tensioner collars, use em?
I have read that the pressure fed chain tensioners can have a collar installed to prevent colapse in case of seal failure. I see that some of the engine builders use pressure fed tensioners, do you use these collars?
Thank you
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 08-12-2011, 03:32 PM
abit off center
cgarr's Avatar
I use the internal stop upgrade, does pretty much the same thing.
______________________
Craig
G2Performance
Old 08-12-2011, 03:38 PM
E Sully's Avatar
Oil Fed Tensioner Modification: ADD SPACER SURVEY
Ed
1973.5 T
Old 08-12-2011, 03:47 PM
Constitutional Liberal
Turbo_pro's Avatar
Use Chain Savers on all types of tensioners just for peace of mind.
The key to survival of all types of tensioners (mechanicals excluded) is to run wide tensioner arms.
Binding of the arms on the shaft is the primary reason for tensioner failure.
Our host sells the wide tensioners and Supertec manufactures a replacement if you have trouble locating the factory models from our host.
Supertec tensioner arms
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 08-12-2011, 04:32 PM
I also used them in my build. Turned out of a piece of round bar stock.
Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html
930 Cab - ex-IA car, 3.4L, 1.2 bar, G50
996 Turbo - X50.
Old 08-12-2011, 04:41 PM
Thanks folks, I had not heard of the internal stop.
w
-Wade
Old 08-12-2011, 06:18 PM
