-   -   964 3.3 Turbo EFI Conversion using Syvecs (Life Racing) Engine Management (http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html)
Spenny_b 07-04-2015 07:40 AM
Valid question, but yes, am pretty sure it will be. Its total volume is just under a litre with about 2/3rds of that being under the filter. From the pics I have, looks very similar to the stock 930 item. Don't forget, it's draining back into the engine via the -4 hose on the underside.
I've run race engines before with very basic "beer can sized" catch tanks from dry sump systems, yeah they fill up fairly quick, but they're just catching and not draining back to the system.
The stock setup only has the breather feeding into the stock air intake/filter assembly, pre-filter....I didn't notice any undue residue when I stripped the engine. If there was a significant amount of oil, I would've been having some pretty major issues on the intake side.
Also, this isn't a track car; there's no way that I'll be able to sustain a high enough engine speed on public roads to cause that much breathing....but we'll see; being a tank of two halves, I could always modify later on.
Spenny_b 07-14-2015 05:29 PM
Just a quick check-in to report....not a lot...
Have hit "the wall" in terms of enthusiasm frankly; you know it's time to go and do something else for a while when the day job becomes more enjoyable than the hobby, and the hobby results in blood pressure going into overdrive.
So, some light duties this last week. I've got to try and remember what I've actually done...
The new breather tank hose fittings are now with the plating shop (along with yet another bag of fixings that need re-plating....God knows where they all keep coming from). I turned a pair of adapters that Lewis then welded onto both a straight M30 tail (from breather tank to air intake), and a 90º M30 fitting (from oil tank to breather).
All welds were leak tested using the sprays below...of course, no leaks found, so off to the plating shop they've gone. I'll then go back up to Think Auto for them to crimp them onto the hoses.
http://img.photobucket.com/albums/v2...6F166F46B8.jpg
http://img.photobucket.com/albums/v2...2F4D5C8124.jpg
The brand new breather pipe from the dry sump tank has now been "modified" (hacked) to remove the swaged on 1" joining section. This is cut right back to within 2" of the inner wing, to allow the new breather tank top hose to fit in place. Measuring for the longer tank>air inlet hose is more complex, as everything needs to be in place (air filter, tract, cold IC pipework, IC itself, etc) to ensure it won't foul anything.
The throttle cable is now back in place. I don't know how, as I'm using the same mounting brackets as before, and I took measurements when I designed the linkage to ensure the cable socket/balljoint sit in the same place as the original...but...it was loose as hell, well beyond taking the slack up using the outer cable adjuster under the chassis. Anyway, another piece of turning resulted in a nice fitting plastic spacer that slips over the inner cable and fits onto the hex adjuster, to tension the out sleeve by 30mm or so. Just need a second warm body to eyeball the linkage versus the pedal being depressed. We'll then check the laptop in a few weeks to ensure the throttle pot is still being rotated fully as far as the ECU is concerned.
The clutch pipe, flexi hose and slave cylinder are all now fitted....now that's a job I wished I'd done before reinstalling the motor. What an utter s**t of a job. Lost count how many times I smacked my head on many things that are extremely solid. Like the vehicle lift. Swore. A lot. To add to the frustration, sods law saw an M8 nut fall out of my hands (whilst contorted), straight down the aperture in the bellhousing. FFS. Thankfully after a few attempts to not daring to move anything and using a magnet (which failed), a few degrees of rotation whilst in gear, saw it fall out the bottom again.
The new Mikalor stainless clamps arrived the other day, now the correct size for the hot air ducting pipework. My mistake, the pipe dia is bang-on 68mm, so I ordered 68mm clamps, logically. Unfortunately, they don't clamp tightly at 68mm, so 64-67mm is actually the correct size......but I also then noticed that the 1-ply silicon ducting hose for the HVAC system was also wrong. I ordered this a few months ago, 1m of 76mm ID. Yet again the idiots I ordered from sent me 70mm. Another fortnight lost sending it back and waiting for their painfully slow RMA process to kick in...then a chaser call from me, where I'm sure I was being setup for a wind-up TV show....please, tell me, am I being unrealistic in expecting somebody to grasp the fact that what I ordered was 76mm, what I recevied was 70mm, and could they please....pleeeeeease....send me 76mm?...Nope, this guy couldn't grasp it. Twat.
So, guess what I received yesterday? No, don't be daft....I got a silicone T-piece. Just like the one I ordered to use on the air intake. It is 76mm though, but WTF???! Why on EARTH would they send me this? Clearly I was speaking with the worlds most moronic individual.
On the subject of frustration, first I had to endlessly chase the clutch hose people, now it's been returned I'm having to again constantly chase them to refund me. My life is spent chasing people or bollocking them for sending wrong things. Frankly it's getting boring (there's other stuff on the Lotus which is also wrong/crap/late, adding to the frustration)
Am I sounding frustrated? :rolleyes: (rhetoric Q).....Oh well, we'll see what arrives in tomorrows post.
Gearbox mounts are all now tightened...next job, and I do keep on saying it, is to run the fire extinguisher hose through and really think hard about how I'm going to mount 6x nozzles without drilling holes into the chassis for the brackets. It's got me worried, there's so little room in there, but I'm sure a couple of cups of tea will purge some ideas out of the grey matter.
In parallel, I must get back onto the AC lines project-ette, now that we know where the OAS tank is mounting.
Will keep you posted, but probably not a lot happening for the next week or so.
Spenny_b 07-15-2015 04:00 PM
Maybe the worm is turning.....
Per #subject, perhaps 'im-up-there is giving me a bit of a break...ok, so I haven't moved things on massively this evening, but it all did go very smoothly indeed, no wrestling, swearing or bruising.
The silicon 1-ply ducting hose arrived this morning....cue drum-roll and blood pressure increase...and breathe. Finally, I've received the 76mm ID hose I need for the hot side heat ducting into the rear blowers.
All now cut to length and installed with new stainless jubilee clips, plus full stainless Mikalor clamps for the rigid ducting pipework onto the heat shrouds on the headers.
http://img.photobucket.com/albums/v2...09C3386593.jpg
http://img.photobucket.com/albums/v2...54C7D3D079.jpg
http://img.photobucket.com/albums/v2...AF4F35A5FF.jpg
A quick lunchbreak tinker had me thinking about the AC lines again, and whether I could massively simplify the new lines project.
You may remember from a few months (and pages) ago, that one option is to buy from the US a pair of Denso > AN adapters, then use a pair of 90º AN fittings that are swaged onto the hoses. But, now that the engine is back in, I was a little concerned that the additional height of the 90º bends *may* interfere with the engine lid. Plus, more fittings = more opportunity for leaks. Of course, the additional time and cost (those adapters seem damn expensive for what they are) of getting them over from the US, on a punt, is very much my Plan B....so, my new Plan A....
Now that the old lines have been butchered to remove the lengths I need to retain (what I refer to as the Z pipes, that go into the inner wing and screw onto the lines which run to the front of the car down the LH side), it's left the other ends potentially redundant.
However....Looking a little closer at them, an idea I considered a few weeks ago struck me as feasible. I had a play to remove the old rubber hosing from one of them, and it got me pondering whether the outlet pipework was brazed into the "block" which bolts down onto the pump. If so, then potentially we can heat it, rotate to the new orientation that misses the IC, and re-braze or weld.
If it isn't brazed, and can't be persuaded out, then we'll just carefully cut-rotate-weld the pipework. That's the theory, anyway. Have left them with Pete for him and Lewis to play with. If successful, then Burgaflex can hopefully just swage new hosing onto them, job's a good'un.
Spenny_b 07-17-2015 07:33 AM
Quick progress track....
Last night saw the rear anti-roll bar get reinstalled; this was re-cotated in the very first batch of parts almost four years ago, so it was quite satisfying not only seeing another bag of re-plated fasteners disappear, but also 3 more items from my home office (which hasn't been used as a home office for, well, almost 4yrs...).
All installed beautifully, although I did start twitching when I had to re-assemble the drop links; they've not been removed from the car, thus are still looking their age (you have to draw a line somewhere.....apparently). This will be addressed as the often mentioned Phase 2 project, which is the far simpler suspension upgrade and refurb plan.
http://img.photobucket.com/albums/v2...4A6E8A27AB.jpg
http://img.photobucket.com/albums/v2...19BD960525.jpg
I collected the re-plated breather hose fittings for the OAS tank over the lunchbreak. Interestingly, when I questioned why they hadn't come up nice and shiny like the original parts were, I found out that there are 2 ways to BZP items; acid dip and cyanide dip. Most parts are simply acid dipped, it's the "commodity" process; looks nice and presentable, but actually isn't that robust. It is a lot cheaper though. The cyanide dip, however, does come up duller as you can see in the pic below, but is more robust. And more expensive. So there you go. I hadn't appreciated that until today.
http://img.photobucket.com/albums/v2...5658646061.jpg
I had a long FaceTime chat with TK Chris again last night. Always great to catch up and talk "in person", and of course I'm extremely grateful for him taking the time, he's always busy of course, and just re-assure me on a few things or throw some ideas around. It's been said many many times over on the 930 Supercharging/Turbocharging forum, but he really is a stand-up guy.
One of the questions I had was around the gear shift feel; you may remember that I installed an FD Motorsports "Golden Rod" rear shift linkage a couple of years ago, but for the life of me I couldn't remember what the shift feel felt like the last time I drove the car. I only had it for 6mths before taking it off the road, of course. My concern was around the spring tension when moving across the gate, from the 3-4 > 1-2 position - this felt nice and strong...compared to the 3-4 > 5 gate movement, which feels a lot weaker. I had a horrible feeling that something had become dislodged inside the gearbox.
A quick requisition of my Brothers services to actuate the lever while I crawled under the car to inspect the rotatation of the selector shaft proved that it was moving the same amount in either direction. Apart from bolting the Golden Rod on at either end, there's nothing that could go wrong, so was pretty sure there was no fault there, but you know what it's like, you replace something (and sent the original back over the Pond in exchange..) and immediately it raises a doubt. Was I imagining this strange, weak, shift feel?
Turns out I was - Chris ducked outside....into the 108ºF Arizona sunshine....grrr....to check a C2 Turbo that happened to be in the shop. Ahhh, thank you Apple...the beauty of FaceTime allowed Chris to examine my shaft and vice versa....er.....you know what I mean.
(come on, a gearbox innuendo gag was dying to be had...)
Nothing to see here, move along. Both shift actions looked to be the same, and I'd simply forgotten (got paranoid....). Which is good, something less to worry about.
Oh...almost forgot...those clowns with the silicone hosing? I received another parcel today...another metre of 76mm 1-ply ducting hose. Sublime to the ridiculous!
TurboKraft 07-17-2015 01:00 PM
Lol good catching up with you, Spencer. Technology is brilliant when it works.
Too funny about that ducting. I think they're just messing with you now!
Innuendo remark sure to get a response from Paul and/or Ronnie in 3...2...1...
Spenny_b 07-17-2015 01:59 PM
Originally Posted by TurboKraft (Post 8715007)
....Innuendo remark sure to get a response from Paul and/or Ronnie in 3...2...1...
Sssshhhhh!!!!
I know Paul has been reading this thread, but I don't know about Ronnie...For gawds-sake don't mention it, I don't want this diary becoming a insult-fest!! :D:D:p
304065 07-20-2015 05:17 PM
And I was worried that you were over-detailing the project! And here you go leaving these un-anodized with Sulphur, like the Argus fittings!
http://www.early911sregistry.org/for...1&d=1340171506
I'll say it again . . your attention to detail is unbelievable. . . and your patience and persistence with this project are LEGENDARY! Persevere my friend!
Spenny_b 07-26-2015 12:57 AM
Haha, thanks John. Really do appreciate the comments ;)
Well, with that perseverance, a momentous couple of events that I've not yet documented. Firstly, last weekend saw Dad and I crank the engine over for the first time. With the lower plugs removed, it only took a few seconds for the oil pressure to build.
Next job was to check the fuel pumps. It's been a busy week this last few days, so no real opportunity to play around in the garage, so with some time yesterday and the car still on the ramps, I removed the front fuel pump hatch, just to be able to keep an eye on everything. With the MBE s/w (and I imagine most other brands), you can manually trigger the output pins, only for 10secs or so, but one of the o/p's is the fuel pump relay trigger. Doing this has pumped the fuel around nicely, both pumps whirring very smoothly. They certainly don't make the racket that some users of the Bosch 044 complain about - I can only presume its the rubber sleeve capsule that Porsche uses, which damps the sound this much.
Anyway, at the moment, I can't register a fuel pressure reading on the MBE dashboard. There's definitely fuel pressure at the sender, that's all checked, and the configuration setting in the ECU looks to be fine.....so todays job will be to buzz the loom through.
With my neighbour Ian available as another set of eyes and a handheld extinguisher operator, I took the brave-pill, lowered the car off the ramps and got it outside for the first fire-up. Exhaust tailpipes quickly pushed onto the silencer, no intake system or IC in place, just really wanted to see the engine turn over before bolting everything back in place for the final time.....see video below!
<iframe width="560" height="315" src="https://www.youtube.com/embed/9wIUJXn84_o" frameborder="0" allowfullscreen></iframe>
Bearing in mind that I don't have the throttle pedal back together inside the cabin (todays other job), this fire-up was purely on the key....which I'm pretty chuffed with, that's not too shabby at all. Interface to the tacho also worked perfectly - it may have been necessary to use a pull-up resistor, depending on the type of tacho drive the guage uses, but clearly this isn't necessary.
Really do like the exhaust note - not shouty or track-refugee at idle, just sounds (imo) pretty damn menacing....a little like the Nissan GTR's I've heard.
Fuel pressure sensor check - without this I can't set the fuel pressure regulator, so as long as the weather holds, the car will be rolling back out shortly for me to apply ze meters.
Back later with another instalment....
Spenny_b 07-26-2015 06:41 AM
Well, that was a productive morning!
I noticed the other day that the dash oil pressure gauge was mis-reading when we cranked the engine over last weekend. It was reading 0 then flew off the top of the scale when the pressure increased. My suspicion was correct, simple case of the wires to the oil pressure sensor being reversed. I was a little concerned, as this loom was a new one that I made about 3yrs ago, replacing the stock one that became largely redundant after the removal of the CIS setup.
Turning my attention to the fuel system and pressure readings, all the loom connections buzz through fine, +5v on the pink wire, 0v and continuity to Gnd, with the orange signal wire going to pin A34 on the 9A9 connection. The MBE configuration for programmable input pins looks to be fine as well. When I swapped the Oil P harness onto the Fuel P sensor, it also read as I would expect...anyway, I've now got a fuel pressure reading on the EasiMap s/w, albeit not quite the "panel" in the dash I was expecting to give me the reading (and conversely, the one I was expecting it to work on, still reads 4psi). So everything looks good, it may well just be something that needs to be configured deep in the settings, but it's working well enough for me to adjust the fuel pressure regulator.
Time to fire her up again, keeping an eagle eye on things as everything warms up. A quick break in the warm-up cycle to check and top-up the oil level (in anticipation of the thermostat opening and needing to fill the oil cooler circuit), then another restart and about 30mins of warm-up.
Oil pressure at cold idle was 4bar on the dash, 54-55psi on the laptop. I was surprised how long it did actually take to warm up fully, but once the oil temp gauge on the dash started registering, the oil pressure dropped nicely down to 2.5bar; again, the laptop reading ever-so-slightly less.
I could just about reach inside the RH wheel arch to test the temp of the oil lines....flipping hot....but as the car is right up against the garage wall on dollies, I haven't yet had a good inspection for leaks.
A couple of observations; over the last few days of just turning the ignition on, the rear blower fans were switching on - not full blast, but I'm sure they never used to do that. After a full temp cycle, I now notice that when switching ignition on, the fans are off! So, whether the 964's over-complicated cooling system has caused the CCU to re-calibrate itself, I don't know, but as I type, they're behaving as expected. I also noticed that whilst sitting in the cabin, the ventilation system would only blow hot air, no temp control. Time for me to dust off the paperwork for the climate control system and refamiliarise myself with it.
Second observation is that both the laptop and the multimeter are reporting a charging voltage of only 11.6v. Chris and I talked the other day about whether some damage *may* have happened on the dyno. The alternator belt was disconnected, as we were not loading the alternator with a charging circuit. Leaving it open-circuit but being driven would've blown it, however, bearing stiction in the fan assembly meant that it was being driven very slowly. Thoughts are that this slow speed unloaded drive shouldn't have caused any damage to the regulator circuit, but I'm now wondering whether it has. Engine fires-up beautifully, no hint of slow cranking. So the behaviour doesn't match the readings, but I could really do without having to remove the alternator, a complete cow of a job.
This afternoons job will be to shuffle the car over to the other side of the garage, and do a thorough leak inspection. If ok, then I can finally start re-installing all the inner arches and the RHS "shark-fin" bodywork.
The interior can be refitted again as well - loom looks to be good, and the revised plan to run the fire extinguisher lines in the centre console means the carpets can go back.
The throttle pedal needs to be re-assembled, then I think the clutch pedal system can be filled and bled.
I forgot to mention, that the hoses for the oil-air separator tank are now finished with my custom couplings swaged on perfectly.
http://img.photobucket.com/albums/v2...E9E541F9D7.jpg
Tempting to refit everything, however, the extinguisher lines are going to be a little easier to install without the air filter and breather assembly in place.
Pat RUFBTR 07-26-2015 10:01 AM
Bravo Spencer !!! ;-)
Spenny_b 07-27-2015 04:30 AM
Thanks Pat! You well?
Spenny_b 07-27-2015 05:09 AM
Ah well, looks like I've got to bite the bullet and remove the alternator to rebuild it. :rolleyes:
Hooking up the multimeter directly to the starter motor contacts reveals only a marginal improvement, reading 11.9v at 2,000 rpm. 300mV voltage drop to the front of the car; not great but tolerable (and in fairness, the 11.6v reading yesterday was at idle, not 2,000, so it may not be as much as 300mV). So, unless I've managed to completely cock up the new engine loom that connects the alternator to the starter motor - I'll check end to end resistance later - then it's a safe bet that it may be past it's best, perhaps worn slip rings and brushes, rather than a failed regulator pack....or both.
While I'm at it, I'll replace both bearings, daft not to for £9 each, plus the slip ring and plastic bearing receptacle cap.
If anyone needs it, there's a great rebuild how-to thread from JWPATE here ....I'll let you know how I get on.
Spenny_b 07-27-2015 06:08 AM
Well...lucky break time!!
I can't quite believe this...but after trawling the 964/993 forum for alternator rebuilds - see above - I also found a thread in the search that briefly mentioned the warning lights, "christmas tree" effects and the clock module. The thought occurred to me whether by having that clock module unplugged, would/could that influence the charging reading?...Of course, mine's no longer a clock it's a boost gauge, but the warning light architecture remains the same.
Well, it turns out that it can/did. Quickly plugging the gauge back in, then firing the engine up with the DMM still connected to the starter motor and engine ground....and I now have 13.9v at idle. Was only a quick check before having to jump onto a conf call, so didnt have time to warm the engine sufficiently to check at higher revs. But, it's far closer to what I'd have expected and it saves me having to remove the fan.
Beers tonight!
jsveb 07-27-2015 11:54 AM
A huge congratulations.
That ain't no GTR sound. It sounds like an awesome flat 6 ;)
Absolutely no drama, as expected.
Spenny_b 07-27-2015 03:56 PM
Thanks buddy!....yeah I more thinking that the idle note was deeper and smooth....very smooth actually, as opposed to a shouty "cack-cack-cack" racecar sound. I always hear GTR's and think they sound quite baritone. Don't get me wrong, prodding the loud pedal a little and it's very distinctively a flat-6.
"No drama, as expected"? :D ...I certainly wasn't that confident, I was cacking it! In the end I just went for it....
Was saying to my mate Matt this evening that something occurred to me earlier today whilst sitting in the car; no NVH harshness at all, sewing machine smooth despite having 964RS engine mounts and TurboKrafts uprated gearbox mount. I was half expecting something a little harsher (but glad it's not...that wasn't the brief, remember?)...guess all that OCD behaviour with balancing the rods/pistons/gudgeon pins, then surface grinding my set of valve spring seat shims, actually paid off.
The 964RS flywheel and GT2RS clutch assembly is also drama free; no idling issues like so many folk experience. Dying to see how well it all picks-up under load!
Not too much activity tonight. Dad walked over and heard it fire up for the first time. Got one of the inner arch sets fitted, along with the RHS shark-fin panel, then a considerable amount of head-scratching about the AC lines. Again. I think I have a plan, finally. More after I speak with Robert at Burgaflex tomorrow.
Spenny_b 07-28-2015 02:55 PM
Cooking with gas today....
Spoke to Robert at Burgaflex, and we have a plan with the AC lines. After researching options that potentially use SAE screw on fittings, I think the height clearance to the engine lid is going to prevent this from being a good option, apart from anything else, we'd be looking at about $80 to get a pair of Denso adapters into the UK, then the cost of buying the wrong fittings, plus the time involved.
So, the plan as I see it, is to re-use the Denso blocks but modifying the inlet/outlet pipes to avoid the intercooler. Scabby looking but they'll clean up a treat, and will (of course!) be re-plated once modified.
http://img.photobucket.com/albums/v2...t/IMG_7310.jpg
A week or so ago, I took the fittings along for Pete to have a go at heating; the pipework looked to be brazed or soldered in, certainly not welded. However, the fittings weren't playing ball, and one of them tore off when twisting.
My Plan B last night was to re-use the tails of the original hose fittings, i.e., the part sitting inside the hose and onto which the ferrule will be swaged, then order some 1mm walled mild steel tube in the correct diameters, and bend them myself. A simple case of welding at either end would then give me a bespoke fitting to clear everything.
However...there's a Plan C! Speaking with Robert, an easier solution would be to purchase a couple of 90º fittings, remove the nuts from one end (leaving the hose tail) and then welding these onto the Denso blocks....reduces the number of welds needed. A little neater and removes half of the leak risk.
The pics below show my thinking, albeit I was using the old tails to illustrate to Robert what I was looking to achieve and also what I was looking to clear in terms of hardware. I need to ensure that I don't obstruct the M8 AC pump mounting bolt; that could really ruin a day, should the pump need removing or belt tensioning.
Without the intercooler fitted....
http://img.photobucket.com/albums/v2...t/IMG_7312.jpg
http://img.photobucket.com/albums/v2...t/IMG_7311.jpg
Then with the IC installed, showing the overall window of space I have available...
http://img.photobucket.com/albums/v2...t/IMG_7313.jpg
http://img.photobucket.com/albums/v2...t/IMG_7314.jpg
For the pressure fitting (the smaller, inboard one), I can't decide whether to try and use another 90º coupling or whether to use a straight tail into the side of the block. Ultimately, I think it'll be determined by the bend radius of the pressure fitting and whether I can get it close enough to the Denso block so as not to impinge on that mounting bolt....
http://img.photobucket.com/albums/v2...t/IMG_7315.jpg
.....For the sake of a few pounds, I've ordered one of each.
So, 2 x 1.5m lengths of hose plus 3 x fittings are now paid for and winging their way south. All I then need to do is accurately cut the original ally "Z" pipes that interface onto the chassis lines, then mock it all up with indexing marks, and ship it back up to Bergaflex for crimping....hoping that I get it right!
In other news....
  • A pair of Mikalor W4 full stainless clamps have now been ordered for the exhaust tailpipes, along with a tonne of other M6 fixings, that I always seem to be running out of...
  • The intercooler mounts are now set in the correct location to ensure that the engine lid doesn't foul the IC...and it doesn't, so that's another long-standing To-Do item off of the list.
And that's about it for this evening. The Lotus is now ready for its annual MoT and it's time for me to get back to work (proper work, not car work...)
Good evening.
Spenny_b 07-29-2015 08:51 AM
Huzzah! The AC fittings and hoses have arrived already! A look of confusion greeted the courier delivery man whilst I was wondering what on earth I'd ordered/forgotten about. Great service!
http://img.photobucket.com/albums/v2...E25A1FD4E9.jpg
http://img.photobucket.com/albums/v2...4ECE86344B.jpg
So, tonights job will be to start looking into how, where and what to drill and cut. Robert was absolutely correct when he said that the hosing "these days" is of far smaller and lighter construction. By comparison the older suction hoses are massive, heavy and very rigid. Measuring it, 29.3mm OD vs 23.5mm OD.
Finally we may be getting somewhere with this blessed AC sub-project!!
The other hardware also *partially* arrived today....one Mikalor clamp missing, but in todays post. No biggy, not in a rush for it.
Pat RUFBTR 07-29-2015 10:36 AM
Hi Spencer, For me that drags on near the body which is in Belgium, the painter left! I have to get back parts engine over there which are restored, the problem is that the company is closed because of the holidays, thus I am blocked to go back up my engine.
Thus I am a little disgusted, he(it) is going to need me some patience, many!
I am very satisfied for you, you motivate me, you work great well! ;)
A small photo of my modified exhaust. :)
http://forums.pelicanparts.com/uploa...1438191288.jpg
Spenny_b 07-29-2015 01:16 PM
Ah no!! Nightmare mate. I know the frustration...even getting (what should be) very minor and insignificant jobs finished can become very tedious and soul destroying. My family do keep reminding me that this project should be FUN....stop beating myself up, there is no deadline for completion...not really....it's all just self-imposed pressure. So I do try and listen, take heed and step away for a day or three, then resume.
Love the headers....ceramic coating looks very clean...for the time being! ;) Have you also coated the piston crowns and combustion chambers/valves?
Spenny_b 07-30-2015 04:55 PM
Evening everyone....some great progress this evening on the AC project.
First job was to tidy-up the Denso blocks, so that they can be welded closed. Into the 4-jaw chuck on the lathe, and carefully bored out to a depth of 6mm and chamfer the edge.
http://img.photobucket.com/albums/v2...47A9021C91.jpg
Next job, turn some mild steel bungs, with a chamfer on the outside face. Together with the bore chamfer, a nice weld channel should ensure good weld penetration.
http://img.photobucket.com/albums/v2...D963A53211.jpg
http://img.photobucket.com/albums/v2...F9C45E4A1E.jpg
Some pics showing how the new AC fittings will interface to the blocks. Mounting the suction (larger) hose fitting onto the back of the block was almost an option, apart from it would have to be cut so tight to the radius of the bend in order to avoid the mounting bolt for the pump, it didn't look quite as nice as the option I went for, which was a top entry on the block. As you can see in the pics below, doing it this way means that the two hoses now neatly sit above each other.
http://img.photobucket.com/albums/v2...710C2B6150.jpg
Suction fitting was then cut at the correct angle, then time to mount the X-Y bed and vice onto the pillar drill. The table of the drill was then rotated so that I could drill the new hole on top of the block at the same angle as the hose fitting....
http://img.photobucket.com/albums/v2...8988F40E37.jpg
http://img.photobucket.com/albums/v2...B802B5913B.jpg
...all turned out very nice, with a final cut to 13mm ID, matching the ID of the fitting.
http://img.photobucket.com/albums/v2...88E2317AA4.jpg
Next job was to drill the side entry hole into the block for the pressure line. Easy job, and I've retained the flange on the hose fitting, so that there's more metal to weld with.
http://img.photobucket.com/albums/v2...34A40845ED.jpg
Final positioning of the two hoses....
http://img.photobucket.com/albums/v2...6F274EDEF5.jpg
Next task was to start routing the hoses around the back of the engine. No pics of this yet, but the ally "Z" pipes have been repositioned and screwed onto the chassis lines. Against these, the ferrules were fitted to the end of the hoses in order to see where they're going to sit, relative to the hose retaining clamp on the rear firewall. Ally pipes then marked, rubber hoses clamped into position in said firewall clamp, and then cut to length at the pump end.
I may look into making a bracket that mounts off of the back of the power steering pump. Onto this, with a 90º return, I'll see if the hoses are flexible enough to pull down and be retained using a giant P-Clip. I'm not convinced it's actually needed - there's nothing that the hoses will rub against, and it's unlikely they'll move very much over that short length...it's just a tidyness (OCD) thing....
Plan for the weekend is to get the AC fittings over to Pete for welding and leak testing, then they can go to the plating shop for a quick dip.
Pat RUFBTR 08-03-2015 05:42 AM
Hi Spencer! SmileWavy
I know well that the ceramic surface treatment will not remain eternally so clean, but I don't mind because I wish especially the thermal efficiency to contain at best the heat of the exhaust. The company does not make the covering of the internal surfaces of the engine.
A link if you wish to follow the evolution of my body and my inside.
https://www.facebook.com/pages/9-One-One-Motorsport/342673192496116?fref=pb&hc_location=profile_browse r
Good luck for the continuation of your repairs, you are almost at the end of the tunnel!
Sorry for the link, he does not display.
Spenny_b 08-04-2015 09:24 AM
Thanks for the link mate, I'll check-in regularly and augment my uni-lingualality with Google Translate!! Some lovely looking toys being document there ;)
Spenny_b 08-04-2015 04:23 PM
Mid-week(ish) update....
The AC fittings are now welded, collected on Saturday and leak tested. A fine job of welding, very neat indeed.
http://img.photobucket.com/albums/v2...566EBC6B2E.jpg
Some time spent filing the backs, where the bungs have been welded in, and radiusing the edges has made them look a lot more presentable.
http://img.photobucket.com/albums/v2...559BEB226F.jpg
Offering them up onto the pump, then running the hoses into the ferrules, and I reckon that's a really neat piece of routing...
http://img.photobucket.com/albums/v2...C9F698E36E.jpg
Doesn't interfere with anything, and more importantly, it clears all of the engine lid structure. In retrospect, this wouldn't have been the case had I bought the adapters shown a few months ago, then used SAE threaded couplings on a 90º elbow.
http://img.photobucket.com/albums/v2...11ACF1468E.jpg
Fittings are now over with the plating shop along with another large bag of M6 fittings; I've had an attack of the "OCD's"...John, stop sniggering....I thought it'd look a little better if I replaced all the BZP caphead screws that are on the top side of the engine, (holding the sensors, sensor brackets, IC mounts, etc), with capheads that have been gold passivate coated....i.e., per the factory stock fixings. Talk about making work for myself, but I'll now sleep oh-so-well knowing this has been done.
At the other end of the technology spectrum, I'd been chatting over with Steve about doing a remote healthcheck of the engine before I venture out onto the highway. My suggestion was to use a remote desktop application, but the version of Windows 7 on my ECU tablet is only Home Premium, so can't be controlled remotely using the native s/w (without hacking, anyway).
So, Plan B, I downloaded TeamViewer onto my Mac (running Parallels and an instance of WinXP), as well as installing it onto the tablet (Win7)...testing on my home LAN, and it seemed to work brilliantly....no messing about opening ports or finding WAN IP addresses, just a case of entering a session ID and a password, and within seconds you can take control. You don't even have to install it, it can be run as a one-time app.
So, some after-hours experimenting with Craig up at SBD HQ this evening, and within 20secs he had control of my ECU....soooo easy, and very snappy in terms of response (apparently). A 17Mbps up/53Mbps down broadband connection helps, of course ;)
First thing he noticed was that my version of Easimap v6 was pretty old....second thing was that my map template for the 9A9 ECU was mismatched to the code level inside the ECU itself....oops.
I had seen some strange behaviour, particularly with fuel pressure readings not displaying as expected. Lo-and-behold, with everything now upgraded, correct templates and chipfiles re-imported, it all works as I would've hoped....my bad, lesson for future, keep everything updated.
http://img.photobucket.com/albums/v2...998F644A8C.jpg
Not a lot else going on really, just tinkering with inner arches and sill (rocker) trims. The gap between the sharks-fin and the rocker on the RHS is different (larger) than that of the LHS. It's driving me nuts....everything lines up, all the studs underneath the car are in dead-centre of the slots on the bodywork, the white plastic clips align perfectly to the red sockets in the chassis...everything looks fine, but the gap is about 10mm vs approx 4mm on the other side....grrrr. May have to live with it, there's no latitude for sliding it back, nor the shark-fin forward, everything is now right up against the arch return lips. Maybe, being handbuilt, they're all like that to some degree? (all bodywork gaps are perfect, door>front wing, door>rear quarter, front wing>frunk lid)
Next job is to get the AC lines back up to Burgaflex for swaging, once the plating shop are done with them. After that, all the intake assembly can go back in. I'm itching to fit it now, but I know it'll just make fitting the AC an absolute sweary nightmare.
Spenny_b 08-05-2015 05:43 PM
A great while listening to the latest instalment of Radio Le Mans Midweek Motorsport; always an amusing listen for a couple of hours whilst spannering.
A lunchtime raid over to the plating shop was an unexpected bonus; all parts dropped off late on Monday were finished and ready to collect....
http://img.photobucket.com/albums/v2...376D80E838.jpg
http://img.photobucket.com/albums/v2...7983FC21AF.jpg
The new bracket that mounts on the back of the power steering pump to fasten the AC hose retaining clip onto...now mounted onto the pump and ready to go.
http://img.photobucket.com/albums/v2...13F559745F.jpg
The hoses for the AC were all prepared the other day, so time to quickly box them up and get them shipped up to Burgaflex; all clearly labelled in terms of indexing marks and positions of the ferrules. Fingers crossed, it'll all come back with the fitting in the correct location.
http://img.photobucket.com/albums/v2...E12DD03AC1.jpg
http://img.photobucket.com/albums/v2...0AAA2041C7.jpg
http://img.photobucket.com/albums/v2...5E779DC008.jpg
This evening, time to sate my OCD and swap over the BZP fittings for the newly coloured capheads and washers. Nice easy job, albeit some things are now really tight to get to.
http://img.photobucket.com/albums/v2...77F3789A55.jpg
http://img.photobucket.com/albums/v2...7015AB1BD8.jpg
The oil-air separator tank is now fully connected to the 2x M30 breather hoses, and the oil tank breather now tightened onto the inlet to the separator tank. The outlet hose isn't yet connected to the silicon T hose on the inlet, see yesterdays comment about keeping that area free until the AC lines are back.
Right, it's late, time to call it a night.
Spenny_b 08-09-2015 01:07 PM
Grr, well that's annoying....thanks to an OSX kernel panic, I've just lost tonights writeup....time to start again. Thanks Apple.
Good progress this weekend. I went up to my pal Shauns workplace to collect the rear bumper and headlamp rims, then spent the rest of yesterday working in the back garden, building it all back up again in the glorious summer sun. Surprising how long a job this is, bearing in mind that the structural part was already done....but getting the correct fit on the rivets, positioning of all the parts and brackets, etc really does take some time.
'Scuse the dust...
http://img.photobucket.com/albums/v2...5705C17E66.jpg
http://img.photobucket.com/albums/v2...D2E34B8DFF.jpg
http://img.photobucket.com/albums/v2...5E41E95578.jpg
The three elements assembled, this time without the over-complicated daft-arse M5 fixings at the top of the shell (the one's that always rust together and can't be undone without grinding....which then melts the plastic if not done very carefully (slowly).
http://img.photobucket.com/albums/v2...AD9ED9888C.jpg
Rear numberplate lamps installed, along with it's identity!
http://img.photobucket.com/albums/v2...74DF9C5360.jpg
There's a strengthening strip that runs along the bottom of the shell; this was then riveted on, then the shell married to the beam with more rivets on the top-side.
The factory "heatshield" for the turbo was a job I've been meaning to get around to for a while. Using new bracketry and clips (there's a pair of brackets that hold the bottom of the outer bumper shell to the structural beam. Onto the LH bracket is mounted the rudimentary bent piece of aluminium), I had just enough of an off-cut of the proper heatshielding material I used a few months ago, to insulate the engine from the turbo/silencer. This time it's a fair bit larger L>R and still plenty of clearance around the GT35R....
http://img.photobucket.com/albums/v2...865C3AC31B.jpg
http://img.photobucket.com/albums/v2...4A8FE55A8F.jpg
That was it for yesterday.....
Spenny_b 08-09-2015 01:22 PM
Todays job was to repair the LH and RH flanking heatshields that install either side of the beam and main heat reflector. 18yrs of use have taken their toll on the thin ally mounting holes, where they're now extremely brittle or non-existent.
http://img.photobucket.com/albums/v2...328FF98A45.jpg
http://img.photobucket.com/albums/v2...CDB2B84151.jpg
http://img.photobucket.com/albums/v2...92EC4EF50F.jpg
...so, some digging around in the offcuts bin, and I found a nice thin gauge section of ally to then make some repair sections with (and yes, if I wasn't now trying to control costs, I'd be buying new, but you just know these are going to be damn expensive)...
http://img.photobucket.com/albums/v2...017D729C15.jpg
http://img.photobucket.com/albums/v2...BB2608A84F.jpg
http://img.photobucket.com/albums/v2...0741B6F50F.jpg
While the epoxy was setting on the heatshields, time to install the reinforcement ribs that run on the underside of the top edge.
http://img.photobucket.com/albums/v2...08922F7483.jpg
When I was sorting out the fixings, I saw the fibre washers and thought it was a bodged installation at some point in the cars life, as there's no mention of these parts in the PET. However, when reassembling, it's pretty obvious that they are required to avoid distorting the plastic when riveting the strips in place.
http://img.photobucket.com/albums/v2...B6ABECFE30.jpg
Spenny_b 08-09-2015 01:32 PM
A quick install of the shields to mark hole positions, then time to fit them permanently with another couple of rivets along the top edge....
http://img.photobucket.com/albums/v2...B92DF12669.jpg
http://img.photobucket.com/albums/v2...8A7F93553D.jpg
At this point, I confess to getting a little antsy about the colour match to the bodywork! A lot of work to undo if it's not correct. Finally, time to enlist the help of my mate Ian, carefully carrying it through the house, workshop and garage....not the time to be tripping over the (far too untidy) skunkwerks.
And it's on!! NOW I feel like I've got my 964 back! And the colourmatch is perfect (knew it would be ;) ) Exhaust pipes aren't aligned yet, but one thing I did notice is that one pipe sticks out further than the other. I know why - it's to do with the angle of mounting of the turbo unit, which in turn has thrown the angle of the silencer relative to the back of the engine - perhaps only 1-2º, but over the length of those tailpipes, it's now about 10-15mm different in protrusion. Thankfully, they're both really easy to remove, so I'll have a final measure, then get Pete to wave his magic TIG wand over it.
http://img.photobucket.com/albums/v2...C8D5764FC7.jpg
http://img.photobucket.com/albums/v2...3B2D0F852A.jpg
Now that the bumper's back in place, I can also start planning how I want those screamer pipes to be positioned (don't forget, these were only welded up in order to get the engine on the dyno - they're not staying like this). Whether I go for something that's very short, 90º and about 2" long pointed downwards, or whether I try and do something to bring them out near the tailpipes, I don't know yet. Tempted to keep is cleaner and simpler and just have stubbies, otherwise I'll then have to consider how to secure the screamers, get some more material bent up, etc....I think I've just convinced myself....
After an hour or so spent clearing the decks a little (I hate working in a mess, but seem to do so all too frequently), I had a quick play with aligning everything and fixing the LH and RH corners to the rear quarters and to the bumper support structure. It wasn't exactly jumping into place, so time to call it a day - it's bloody hot here again today (no, not by AZ standard Chris!) and frankly a beer and the Indy MotoGP is a well deserved bit of R&R.
Spenny_b 08-11-2015 03:37 PM
Evening folks, another major item is now officially off of the To-Do list!
The AC lines arrived back from Burgaflex up in the north of England. I confess to being pleasantly surprised when Robert emailed me at 7.30 yesterday evening, letting me know that they had been assembled and shipped that day on an overnight courier.
http://img.photobucket.com/albums/v2...CB8DE7F9DD.jpg
The connections onto the "Z" pipes; looks to be some welded on swage fittings, very neat job...
http://img.photobucket.com/albums/v2...528350A0BB.jpg
I've been in London all day today, and have got a very early start tomorrow, with a chunk of work to get done between now and then....so....only a very quick play in the garage this evening, but enough time to get them installed.
http://img.photobucket.com/albums/v2...C4C15ACCD5.jpg
They're absolutely spot-on....no twisting on the hoses, no persuading of anything, they just fitted straight in, as planned. The hoses are now fixed to the rear bulkhead, routed behind all the engine breathers and over the PS pump, through the new retaining clip/bracket and onto the pump.
http://img.photobucket.com/albums/v2...6AC69ED350.jpg
It all looks so damn simple in hindsight, but it really is one of those jobs that's been niggling me for a couple of years, things like how to route the pipes, will it foul anything else?, can I source the connections?, can I find somebody in the UK to actually make them?, what if "this?, what if "that"? And of course, you have to work sequentially on this, it's no good going at it like a bull in a china shop, everything else has to be in place and finalised before committing to an idea.
And now it's done. Finished. Once the fire extinguisher lines are run, the intake system can then go back on and the intercooler installed. That's then the engine bay finished.
Right, back to work for me...
304065 08-12-2015 05:57 PM
This is one of those things that will make the cognoscenti go "What?" when they look in the engine compartment. It looks so perfect, so Factory, like it came that way, but in fact represents one heck of a lot of thinking, planning, and execution.
Making the difficult look easy. . . the hallmark of true professionals.
Carry on!
fredT 08-13-2015 02:16 AM
Originally Posted by 304065 (Post 8750818)
this is one of those things that will make the cognoscenti go "what?" when they look in the engine compartment. It looks so perfect, so factory, like it came that way, but in fact represents one heck of a lot of thinking, planning, and execution.
Making the difficult look easy. . . The hallmark of true professionals.
Carry on!
+1
Pat RUFBTR 08-13-2015 11:54 AM
You work great well Spencer, I adore!!!
I have a question, you is hampered(bothered) by the tube to open the cork of yellow oil?
Spenny_b 08-14-2015 04:30 AM
Carry on!
As ever John, you're too generous with your very kind comments (and thanks also Fred)....I'm merely an enthusiastic, OCD-suffering tinkerer. I don't consider anyone to be a professional engine builder unless they can talk fluently about things like parts interoperability and being able to offer thoughts and opinions on how to go about putting together a specification to meet a certain objective. And be able to back that up with a through explanation on the underlying principles of that recommendation, rather than a blatant duplicate of others proven recipes.
I do, however, consider myself a professional spend-thrift!! Friends and colleagues are now starting to ask how much I'm in this project for....and frankly it's more than I bought my first house for....just for this project, not including the car itself. That gets a little embarrassing to be honest, it's only us crazy few that understand the financial and emotional commitment to "the cause".
Spenny_b 08-14-2015 04:45 AM
I knew somebody would ask me this!! I ought to have known it'd be you Pat!! :D ;)
Yeah, it's not a problem at all - most certainly something I was careful to consider when re-making the Denso connections. It's very comfortable in terms of being able to remove the filler cap and then getting a funnel into the neck of the filler tube....
http://img.photobucket.com/albums/v2...57348C7D0B.jpg
http://img.photobucket.com/albums/v2...781FCF408B.jpg
http://img.photobucket.com/albums/v2...2B3F7CE5CC.jpg
Spenny_b 08-14-2015 04:53 AM
A quick lunchtime update....
The AC lines are now in, and I had the cunning idea to secure them to one of the 3 studs on the rear firewall using the same tether ties that the wiring loom is secured with around the engine bay (the ones that push onto the threaded studs and have holes along their length to determine their fit). Up until now, 3 x plastic buttons to secure the sound pad was a tad excessive, so this was a great way to get them tight to the bulkhead and clear from the air filter.
The filter was then sprayed with the dust retention oil and thoroughly worked into the foam cells. The only way to squeeze this into the back of the engine bay is to undo the pressure take-off line that runs to the sender for the OBC boost gauge....easy enough, and allows the cold charge pipe to be swung out of the way.
Filter now installed and tightened into position.....everything fits like a glove, nothing fouls the filter so there should be no airflow restrictions. Can't quite believe it....with the new hoses that weren't originally planned for (the oil tank breather) and the AC lines now in place, nothing is in the way, and it all remains serviceable....quite chuffed with myself!
http://img.photobucket.com/albums/v2...24DE1178AC.jpg
http://img.photobucket.com/albums/v2...0F8456895B.jpg
The intercooler is now back in place, although final mounting cant be done until I receive some stainless P-clips to retain the oil and fuel pressure senders.
Engine bay is tantalisingly close to being finished....
Pat RUFBTR 08-14-2015 06:53 AM
Bravo Spencer! :D
304065 08-20-2015 09:31 AM
Spencer, always remember the fundamental aphorism of the 930 owner (from when the cars were new back in the 1970s). . . "You can live in your car... but you can't drive your house!"
And it will be a very fast house indeed.
Spenny_b 08-25-2015 11:17 AM
Haha, indeed!!
And even with the property market over here being pretty good, in terms of appreciating assets, it's still being outpaced by air-cooled Porsches!!
Right, that does it...off to sell one of my bedrooms to finish the project...
Spenny_b 08-26-2015 03:03 AM
General Update
Post vacation progress update time....
Some re-alignment and tightening work on the brackets for the intercooler, specifically now making sure the hot charge pipe is in the right place and tightened. The rear cold charge pipe alignment continues to irritate despite me trying a few months ago (or maybe even a year ago now?) to shim the mounting plate to bring the IC height inline with the flange on he cold pipe....I guess by reworking that rear mounting that was shimmed - to accommodate the breather tank - something subtle has happened and it's not lining up again.
I can see it's not going to be long before I either rework the pipe to put a second quick-release coupling in the longest length, thus allowing for some compound misalignment, or just chop the charge pipe, flare both ends and use a silicon joiner hose. Having to wrestle the whole thing each time kind of defeats the object of QR couplings!
Of course, this is NOT a problem with the TK IC, this is purely down to keeping everything so tightly locked into place when fabricating the charge pipes in-situ...which is tricky, as it has to be done without the O-Rings in place, and it's that 1-2mm of play that's now hindering fitment.
(Chris - I have one of my cunning ideas on this - I'll buzz you at some point and run it past you?)
Okay...next update, the interior carpets are now glued back into place again. These had to be carefully lifted to allow me to remove the engine harness for the dyno. Easy job and now done, along with rear seats, parcel shelf and seatbelts being refitted. Next job on this [broken record mode=on] is to install extinguisher tubing inside the centre console trim.
Have made good progress on the installation of the traction control and variable boost controls. If you remember, I'm re-purposing a Carrera 4 panel so that it looks bone-stock. I made a lot of the adapter rings up a good while ago, but with the Raychem boots on the back of the switches, the plan looked to be out of the window. I made some rings that were a snug fit over the OD of the rotary switches, and a snug fit on the ID of the white plastic tubes that are part of the C4 panel assembly, however, the heatshrink boots were glued over the OD of the switches. At this point I thought I was going to have to permanently bond the switches into the tubes; far from ideal. With some careful cutting (God the Raychem boots are hard!...no fear of anything penetrating them!), I've now exposed enough of the switch body. The plastic adapter rings are now bonded onto the switches....
http://img.photobucket.com/albums/v2...E41864CC17.jpg
http://img.photobucket.com/albums/v2...19F25EBAD2.jpg
....and are a perfect fit inside the tubes.....
http://img.photobucket.com/albums/v2...C38836F107.jpg
The spindles of the switches are the perfect length to mate into the adapters that the switch knobs fit onto, albeit I'm re-using one of the 3x holes that are usually loaded with a ballbearing and spring. An M5 tap and a grub screw will ensure that these spindle adapters are locked onto the flat of the spindle itself.
All that needs to be done is seat the switches to the correct depth and lock the spindle adapters, then orientate the switches in the plastic tubes, to make sure the knobs align to the legends on the panel. Easy!
http://img.photobucket.com/albums/v2...6C995E6108.jpg
Following that, on the same harness is the output from the ECU for a shift light (although I'm pretty sure I wont need/want this) and then signal feed from the Stack boost gauge, which we built into the engine loom for neatness. So, once that's connected I just need to route a +Ve and Gnd feed to the gauge itself, and it can be installed permanently.
Back onto the chassis, more parts which I ordered before going on holiday have arrived....completely unremarkable apart from the total price of >£270!
http://img.photobucket.com/albums/v2...2DC1BBA79C.jpg
Back when I was on motorbikes, there was a theory that said Japanese bike plastic was more expensive (gram for gram) than gold....I'm pretty sure German plastic and fasteners aren't far off either! Anyway, the correct gearbox cover is now here, no snapped tangs or mounting brackets.
Wheel centre trims - argghh - nothing is bloody easy on this car. They should be a slam-dunk easy part to order and fit, yes? Nope. The fronts snap into place fine but the rear ones won't seat correctly....clearly a different spigot dimension, as when I checked my German copy of the PET (rather than the US one), it has additional descriptions for "M402" and "M403"....16" and 17" Cup Wheels respectively. Although that then begs another question....they never fitted 16" Cups onto the Turbo, so why would there be a "Turbo" inscribed centre cap for a 16" wheel? God knows. Got grumpy last night and went and watched TV. I'll remove a rear wheel later and have a look from the inside.
A/C O-rings are also wrong, FFS. That's another job I cant quite cross off the list.
Before going on hols, I received a metre length of black single ply ducting hose, for the front bumper ducts. I'll take pics later, but again, was disappointed to find that instead of receiving the 85mm ID hose I ordered (yes, the same "hose prats" that have cocked up every order so far...), I got 80mm....not even the more common 83mm. Was about to maul somebody over the phone but thought I'd try it anyway, gently reshaping into an oval and pushing it over the duct outlet....lo-and-behold, I reckon I can make it work ;) Just need the rain to abate for a few hours one evening so I can pull the front PU off and try a few things.
A job I've been avoiding for a few weeks is to bleed the clutch slave cylinder. Potentially easy to do with the car in the air and me underneath, manipulating the slave cylinder bleed, but it needs to have somebody in the cabin pumping the pedal - not something I really want to do in terms of unbalancing the car lift with me underneath....I'm sure it would be fine....but....
I've had pretty good success with a Gunsons Easi-Bleed rig before. These are a pressure bleeding system that uses an inflated car tyre as the pressure source. It's ok, apart from making sure there's not too much pressure, and then pumping up the tyre every few minutes. The reservoir bottle is also quite small and drains quickly, so doing this with the car hoisted is possible but not ideal. Time to invest in a proper pressure bleed rig, a Sealey V820, only £40 on eBay, should arrive today. I was also mulling over the idea of making a remote bleed hose to bring the bleed nipple out to an inner arch or engine bay...probably the former, as I don't want yet more paraphernalia in with the engine. I'll put a call into Think Auto and see what we can do; I'm sure I have a spare length of -3AN hose somewhere.....
Spenny_b 08-26-2015 03:39 AM
Hub Nuts
Had a (hopefully) good result with sourcing a torque multiplier; I think I mentioned a week or so ago, that I snapped the knuckle on a 2ft breaker bar in the process of trying to undo the front hub nuts? Even with a neighbour weighing on a 3ft x 3/4" drive bar, it wasn't budging (they're done up to 460Nm).
So, I was about to buy a Sealey multiplier - mid-range quality but in fairness, that's fine for a tool I only need once in a blue-moon. I got as far as the checkout then thought I'd give eBay another shot for a Snap On tool; I missed out on one the week before, and was a little surprised to find the next model up in the Snap On range with no bids. New with just a few storage marks.
Long story short, it'll be on it's way on Friday when the vendor returns home, suffice to say it's the GA-185 2,000lb/ft rated model....3/4" input and 1" output.
http://public.snapon.com/R_RRD/ItemD...ges/GA184A.jpg
In addition, the vendor also offered me a VERY good price on a new L872 ratchet head and handle..
http://public.snapon.com/R_RRD/ItemD...mages/L872.jpg
http://public.snapon.com/R_RRD/ItemD...ages/L872H.jpg
...600lb/ft rating (!), same 25" length as the multiplier....all for £50 more than I would've spent on the Sealey multiplier alone. Of course, I don't really need this, as I'll be using the 3ft breaker to undo the nuts, then 2ft torque wrench to tighten the new ones....but one can never have too many tools. These are the first Snap On items to be added to my tool chest!
Jeff Alton 08-26-2015 07:19 PM
Have the snap-on tool in your pic, though our is 1/2 input and 3/4 output. Works great, though rarely used!
Cheers
