-   -   964 3.3 Turbo EFI Conversion using Syvecs (Life Racing) Engine Management (http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html)
Pat RUFBTR 03-25-2018 04:47 AM
Perfect Spencer ! ;)
kevinbodman930 03-28-2018 09:35 PM
I really look forward to the book..
Spenny_b 03-29-2018 08:04 AM
So, steady progress just crossing off those to-do list items. Monday was a great Day #1 of my vacation week, getting a lot of the stuff done that I can - other items needed me to have the anodised water parts back before I can sensibly tackle them. Thankfully a phonecall into the plating shop and I was on my way over to collect them on Tuesday.
Off the top of my head, Mondays work:
  • Spark plug indexing spacers are now all done.
  • Valve covers now on with the Wrightwood gaskets and some very smart (IMO) domed nyloc M8 nuts. I know it's not factory original but seeing road grime on the exposed threads irritates me somewhat.
  • Coil-on-Plugs are now installed - unbelievably solid on the posts that I've made that mount it to the valve covers. Very pleased with that.
  • The new radiator support arms and water pump support assy is also now mounted.
  • The water expansion tank is now permanently installed; the F/F isolating rubber mount I was waiting for arrived as hoped.
  • Turbo oil drain tank is now back on
  • New sleeving on the scavenge hose that pulls the oil from the tank; just a smaller diameter, looks neater.
Valve covers on, radiator pump supports in place, CoP's installed:
http://img.photobucket.com/albums/v2...d/IMG_2447.jpg
http://img.photobucket.com/albums/v2...d/IMG_2449.jpg
http://img.photobucket.com/albums/v2...d/IMG_2448.jpg
http://img.photobucket.com/albums/v2...d/IMG_2450.jpg
Wednesday day was just a frustrating day in the workshop. As mentioned, I got the anodised parts back, all's well with the quality...
http://img.photobucket.com/albums/v2...d/IMG_2463.jpg
But then it was time to re-assemble everything and it should be "job-done" right? Nope. The engine goblins have been playing, and what I took a lot of time to make sure fitted before stripping it down, now doesn't re-assemble correctly. I've been struggling with clearance of water cooling fittings on the turbo versus the turbine shroud hex bolt fasteners, versus the -10 oil drain fitting; I can absolutely see why hard lines are used for this rather than hosing.
After much scratching of head, and switching around of the -8AN straight/135º connections, I've arrived at the answer.....I need to make a 25-30mm stand-off for one of the banjo's.
The rear banjo is fine - which is good, because space behind the turbo is really tight to the turbo mounting flange. This hose now has a straight fitting to drop it straight down, missing the oil drain line.
The oil feed line can (I think) stay as it is, albeit it's an absolute sod to install the 90º -4 fitting onto.
The oil drain line now needs to be re-made. It's quite a lot too short now that the CHRA has been rotated. I may play with this again, but I am debating the merits of keeping the CHRA with a 20º upward angle. The Garrett whitepaper says that there are benefits to be had with natural syphoning of water through the housing, even without the engine running (and water not being pumped)...however, I'm sure this is intended for cars that are plumbing a turbo into an existing, large capacity and mechanically pumped water circuit. With my setup, I'm not sure that water could be drawn through a static electric water pump. I'm pretty sure that we can achieve the same outcome and keep the pump operating post-shutdown using ECU control.
Anyway, the parts that are re-assembled - to be fair, it's most of it - does look very nice in my opinion; I'd like to think it's more towards a factory look and not a thrown together "DIY" lash-up!
http://img.photobucket.com/albums/v2...d/IMG_2469.jpg
http://img.photobucket.com/albums/v2...d/IMG_2468.jpg
So, this spacer. Well, this is needed for the front water fitting. I'm going to have to make this myself, probably out of ally hex stock. M14x1.5 male thread at one end, and M14x1.5 female thread at the other. Approx 30mm long, with a waisted diameter at it's base, so that it can clear the wretched hex setscrew head....a bit like this one, which I happened to find in one of my parts trays (but is too short to rework/repurpose):
http://img.photobucket.com/albums/v2...d/IMG_2487.jpg
Spenny_b 03-29-2018 08:08 AM
In other news, I've taken this opportunity to install a deluxe fuel filter while the engine is out. I need to switch some fittings on the fuel hoses from metric to JIC, not a major job. The Fuelab 10um filter unit should also arrived yesterday. I thought I'd need to fabricate a new bracket, as it looked a fair bit smaller in diameter to the stock unit, but actually it fits beautifully with a thin piece of rubber glued to the bracket to prevent slipping and scratching. An hour or so switching over the fittings, and it's now in place looking rather smart....
http://img.photobucket.com/albums/v2...d/IMG_2483.jpg
http://img.photobucket.com/albums/v2...d/IMG_2480.jpg
http://img.photobucket.com/albums/v2...d/IMG_2482.jpg
Really am just waiting for the tap and die to arrive, to make that spacer. Weather is too wet to roll the car outdoors and fit the ECU harness through the interior. I suppose it's a good sign that I'm now at a bit of a loss as to what job to do next! Silencer and flywheel/clutch are jobs for when the engine is off of the stand....
Spenny_b 03-29-2018 08:28 AM
Cheers mate!
Haha, that'll be a while away yet!
Spenny_b 03-29-2018 03:17 PM
Brief update this evening....brief because I got the √(sod all) done today! Too much NASA ISS EVA watching.....kind of like watching paint drying, but at the same time curiously addictive....
But...I did get the fuel regulator mounted, using the aforementioned factory bracket. The swapping of the metric fluid fittings for -6 was a little challenging, the "nut" recepticle of the old fittings can only be removed by cutting the hose; it has barbs on the ID. Getting the new recepticle for the -6 fitting also takes some elbow grease. Anyway's it's all done, and hooked up ready for the onwards fuel rail connection.
http://img.photobucket.com/albums/v2...d/IMG_2484.jpg
I also started making the new front water port spacer....
http://img.photobucket.com/albums/v2...d/IMG_2492.jpg
http://img.photobucket.com/albums/v2...d/IMG_2491.jpg
An undercut to allow the die to not leave a shallow thread at the end, and also keeping a shoulder for the copper washer to locate onto. Hoping the tap and die arrive in tomorrows post, then I can finish this little job, and get the water system completely finished.
Spenny_b 03-30-2018 09:20 AM
An unexpected productive days work!
First order of the day was to wheel the car outside and start re-installing the ECU harness through the interior. Way-back-when, I tried to reuse the original rear bulkhead grommet that was part of the old CIS loom. Stupidly, I didn't soften it in hot water before trying to squeeze through the 2x MIL plugs which connect to the engine. Predictably it split the thin centre sealing section. It has a Porsche part number, but apparently nobody can source it as an individual item.
Trying to find something suitable for a 60mm hole is also not easy, so I ended up buying a very nice split grommet from Think Automotive a few weeks ago, with a perfect fit hole to seal against the harness. All I've been waiting for is a break in the weather to get it fitted. Which I got this morning. For an hour.
So, it's all now in, the surrounding area tidied up a little, removing lots of fragments of split/broken sound deadening and adhesive. I can't reinstall the rear quarter panels, carpet or seats just yet, as I need to ensure that enough harness sits engine-side (but not too much).
http://img.photobucket.com/albums/v2...d/IMG_2494.jpg
http://img.photobucket.com/albums/v2...d/IMG_2493.jpg
Elsewhere, the CHRA is now rotated back to it's original position, and tightened against the turbine side; I'm holding off tightening the compressor side until the tinware goes back on, so I can check alignment.
The oil drain hose to the catch tank is now refitted, and so is the 90º oil feed line.
Unfortunately there's no UK postal service on Good Friday, so still no tap and die to finish the spacer with....however...in giving it some thought overnight, I realised that I ought to skinny-down the centre section of the spacer so that it clears the CHRA/Turbine bolt, so another few minutes on the lathe...
http://img.photobucket.com/albums/v2...d/IMG_2497.jpg
Finally, the RH air duct hose from the shroud is now back on; I'm sure that previously I simply pushed it in place, as getting a hose clip on there was troublesome. No idea why I didn't realise that by simply removing the AC pump platform, you can quite easily fit a clip on there properly.
http://img.photobucket.com/albums/v2...d/IMG_2500.jpg
Not sure of plans for this evening, I may get time to reinstall more heat shielding and the silencer mount, as well as the front tinware...we'll see.
Spenny_b 03-31-2018 12:57 PM
Well, the plan soon became clear last night. In the process of refitting the front tinware, with the heatshielding and silencer hanger bracket, then realised that the turbo hanging bracket that mounts onto the crank pulley cover, into the crankcase, was not installed; not accidentally left loose, I'd obviously come across an issue a while ago, and either got distracted or consciously left it for another day.
The problem? The M10 thread in the crankcase has stripped. No idea how, it takes some doing to over-torque an M10 fixing, and I'm religious with torque wrenches...but it is what it is.
http://img.photobucket.com/albums/v2...d/IMG_2506.jpg
The disassembly to remedy the problem was a pain in the arse, only because the lowest 2 bolts holding the crank cover on can't be removed without getting the exhaust manifolds out of the way. Arggghhh!!!
http://img.photobucket.com/albums/v2...d/IMG_2504.jpg
Anyway, it didn't actually take as long as I'd feared, just brew a cuppa and crack on with it. The offending hole is now drilled out and tapped to accept a helicoil, however, the only M10 helicoils I have are only 13.5mm long. A quick-swipe-right on Amazon and I should get a pack of 20mm helicoils on Monday.
http://img.photobucket.com/albums/v2...d/IMG_2505.jpg
This mornings work was more positive; the M14 taps and die arrived (only for me to get the tailstock die holder out...and find an M14x1.5 die already in there! Doh. Of course, I was making ally blanking plugs a few months ago, but unusually, I hadn't stripped it after use and replaced it in my taps and dies drawer. That'll teach me).
The spacer for the turbo coolant port is now finished; not the tidiest piece of work I've done, but functions fantastically, nice and strong, and clears everything it needs to.
http://img.photobucket.com/albums/v2...d/IMG_2510.jpg
http://img.photobucket.com/albums/v2...d/IMG_2511.jpg
I even had some luck with the hose running across to it; I thought I'd have to make a new hose about 50mm longer, but by reversing it and re-routing, it's spot-on, clearing the LH wastegate nicely.
http://img.photobucket.com/albums/v2...d/IMG_2513.jpg
And that's about all I can do on the engine itself until the helicoil pack arrives after the Easter break. I may have a go at making a new under-seat mounting plate for the Syvecs ECU. The old one has all the mounting holes for the MBE unit, so would look scruffy if reused. I'll also look to get the new plate powder coated, as I have a few weeks now until the (rescheduled) engine install date in a few weeks time. A few pals are going to come down and help, followed by the mandatory curry and beer in the evening ;)
Spenny_b 04-06-2018 02:38 AM
A quick catch-up update;
The longer Helicoils arrived the other day, approx 20mm long. The M10 thread that needs repairing has a depth of 33mm.
[Now, whilst repairing one of my lightweight aluminium trolley jacks last weekend with Lucy (as you do...) I needed to drill out one of the M8 bolts in the piston housing, and then also repair it with a Helicoil. I thought it'd be a good opportunity to test whether stacking 2x coils into the tapped hole would work - no reason that I could think of why it shouldn't, unless the tang at the end of the top-most coil doesn't break off cleanly. It was absolutely successful, just a slight "catch" where the two coils butt up to each other.]
Repeating that process with a 20mm + 13mm standard Helicoil into the crankcase M10 hole was also 100% successful....
http://img.photobucket.com/albums/v2...d/IMG_2535.jpg
....however when re-fitting the exhaust headers, three nuts from finishing it, the stud on #5 stripped. I thought it was strange that when undoing the headers, the stud came out rather than the nut coming off. All of the studs were new and Loctite'd with red 263 threadlock, after we drilled out the snapped studs a few months ago. There was one stud that was a little problematic; in trying to clean the thread it kept snagging, locking the tap. I guess it removed just a little too much thread material and it's now ripped.
http://img.photobucket.com/albums/v2...d/IMG_2540.jpg
http://img.photobucket.com/albums/v2...d/IMG_2539.jpg
So, time to remove the headers AGAIN, and fix it with another Helicoil. I took the opportunity to also Helicoil one of the studs on #4, which had also unscrewed. The thread in the head was looking "less than optimal". I then also noticed (!!) that #2 needed attention; this was a stud which was snapped when I bought the car, and was "fixed" using a Timesert as one of the first jobs I asked a specialist to do. Clearly it hadn't been installed as well as it should've been, as the Timesert has unwound itself when trying to undo the nut; the crush nut clearly offering more resistance than the Timesert locking feature.
http://img.photobucket.com/albums/v2...d/IMG_2543.jpg
So, a third Helicoil required. All very easy to do with the engine out....a pig to do in-situ, so thankful I found the issues now.
Interestingly, in doing some research as to whether Helicoils are stronger than Timeserts, I found this >> "Helicoil or Timesert,
which is stronger?"
Some interesting stats in that forum posting from some people who have direct first-hand knowledge. And I have to also say, that I've never had a Helicoil fail on me; perhaps not install cleanly, but they're easily removed. A Timesert kit is also £100 for the tools with 5x M8 inserts. Not cheap, but if the evidence was such that it was way stronger, then of course, I'd buy it....but that isn't the evidence that I'm finding, so I'm sticking with Helicoils. If it's good enough for vast quantities to be used on Boeing 747's and Rapier missiles, then it's good enough for my exhaust studs!
Finally last night I was able to refit the heatshielding that sits behind the exhaust silencer, and then the front tinware apron. The shield needed a little reworking, as I'm now using the TK turbine shield on the turbo, and now looks neater with that rework.
Looking good, I think we're now ready to install the engine into the chassis in a few weeks time. Pics of the new ECU mounting tray over the weekend....
kevinbodman930 04-06-2018 01:27 PM
Not only are you a great mechanic you are also a great writer.I always look forward to your updates.I have caught you on the TAIL end of your build so one of these days I will start from the beginning.
Spenny_b 04-07-2018 04:08 AM
Very kind of you Kev, thanks. I think I've said before, I enjoy the documenting of the project as much as the spannering (it's certainly less frustrating). Quite a few more updates to come yet though!
Costa P 04-07-2018 11:46 AM
Awesome progress mate. Very inspiring.
Any chance you can share with us the secret to Spenny's relentless patience, perseverance and time management? ;)
Iciclehead 04-07-2018 11:53 AM
Amen brother, whatever secret you have to that Spenny, please share....whether it be legal or otherwise, good heavens, I read your thread and then am so tired I lie down and rest!
Dennis
Spenny_b 04-08-2018 06:33 AM
Dennis
http://img.photobucket.com/albums/v2...482d397973.jpg
Seriously though, no, I'm perhaps the least tolerant person I know and thankfully I'm not time-lapse recording the build; a) I don't think even YouTube could muster enough storage to hold such a lengthy project, and b) it'd be a blur of flying spanners being flung around (joking). Better still there'd be no foul mouthed audio (not joking).
The only way for me to keep sane is knowing that every delay and hiccup just means I have more time and opportunity to make the project a bit better.
Time Management? "If in doubt, flat out" ...Mr McRae (RIP) and quoting in a completely different context, but equally as effective for me...A quick post-dinner snooze resets my body clock and then get out into the garage until the very daft hours, as Chris will attest. Not every night by any means (we're all getting older....) but sometimes when you're in the groove and things are going well, then it's easy to keep going.
Maybe I should write that book...
kevinbodman930 04-11-2018 10:51 AM
Write the book..
Spenny_b 04-14-2018 03:12 PM
Evening gang,
Not much to report form this week, been crazy at work then had a cracking day in London with Lucy doing a whole manner of things yesterday and today. How about this for a random selection of activities...
Natural History Museum, London Eye (overcoming her fear of heights), Shrek Adventure (!), very nice twilight al-fresco evening meal on Londons South Bank, people watching....then this morning an early start for last minute cramming in advance of our PADI Open Water SCUBA exams, over to Margate to sit exams (and pass with flying colours), then back over to the Spitfire & Hurricane Memorial Museum for my Spitfire "flight" in their new scale replica cockpit simulator (cool experience), then the first evening BBQ of the season followed by Harry Potter film. I'm absolutely shattered!
Anyway, this afternoon I did also get to fit an upgrade that I should've got around to doing weeks/months ago, to install a new set of "Gucci" grade injectors. I don't know why, but with everything else going on with the engine build, including the water cooling circuit, I suppose it just disappeared off my radar.
My memory was then jogged by seeing Costas project update last week. Cue the panic, as this isn't a job I want to start doing with the engine in the chassis. I saw the Speed Academy YouTube video of a factory tour at Injector Dynamics a few years ago. Needless to say I was very impressed with their attention to detail and incredible levels of obsession.
After some investigation, it looks like the Siemens Deka's I've been using thus far - fine injectors according to some very experienced folks - are very comfortable to about 100hp/injector whilst still maintaining good duty cycles. They will go further, but perhaps out of their sweetspot. We should really be knocking on the door of 600hp on this build (was 544hp on v1.0), so time to invest.
After plugging values into the Injector Dynamics online fuel calculator, I was seeing that the logical choice was an ID850. Speaking with Injector Dynamics the other evening to understand how the 1050x's fit in their range with the ID725, ID850, ID1000's and I very quickly understood that these 3 models are now end-of-lifed. They were off the shelf injectors which were then modified and tested by ID. The ID1050x, however, is designed as a clean sheet design by ID and made for them by Bosch Motorsport. They tell me that it's so well behaved at the lower end of the operating window, that it actually outperforms the older 725 and 850 units. Intended to replace the 1000, they found there was no need to now have so many offerings; the 1050x supersedes all three.
With all injectors installed and the rail tightened back down, time to do a check to ensure that any vertical movement in the injector doesn't bring the o-rings close to un-sealing in the fuel rail. A lot easier to do all of this with the engine on the stand, added to which the engine wiring harness needs another change, switching the current Junior Minitimer connectors to the USCar style connections. ID will sell you adapters to mate JMT to USC, but frankly, thats a hokey bodge in my opinion; new crimp connectors are supplied with each kit, so lets get them fitted.
And here they are....
http://img.photobucket.com/albums/v2...d/IMG_2652.jpg
http://img.photobucket.com/albums/v2...d/IMG_2648.jpg
Now, the only thing is, I'm going to have to relax my policy of no other colour plating other than black or gold. They're very purple!
http://img.photobucket.com/albums/v2...d/IMG_2650.jpg
http://img.photobucket.com/albums/v2...d/IMG_2651.jpg
All of the operating parameters are apparently in the Syvecs code already, which makes life easier come the time to build the calibration maps.
Change of plans with installation; Dad and I are going to get started on it during the week on our own, in good time for Sam then coming down here to build the base fire-up map. Keep you posted.
Pat RUFBTR 04-20-2018 02:17 AM
Hello Spencer,
I am very satisfied for you, I look forward to hearing the humming of your engine! :)
Tippy 04-20-2018 05:43 AM
Injectors have come a long way! I've read small Honda's idle with over 200lb/hr injectors.
That's pure insanity years ago (that you can idle such huge Olympic pool-draining injectors!), but awesome for our current time period in the EFI world!
Spenny_b 04-24-2018 03:16 AM
Yup, I was pretty shocked when I was reading and speaking to folk about them, and they're not *that* much more expensive than stock injectors...bearing in mind that each one is run-in on a test bed, flow tested and their performance profile logged, should any replacement or rectification work be necessary. Money well spent, methinks.
Pat RUFBTR 04-24-2018 03:19 AM
Not easy to make a choice between 1050X and the 1300X if in the future we wish to use the ethanol E85. :)
Spenny_b 04-24-2018 03:25 AM
E85 isn't something I'm planning on using, there's zero talk of it being supplied in the UK - at the moment, the only debate is the description on fuel pumps to clearly show the %-age of ethanol content in the regular fuel...and nobody's even seen that yet! (it's set to increase from (iirc) 5% to 10% at some point in the future, but the Government is aware of the implications on older cars, so like anything, it's slow moving...thankfully)
If/when E85 ever happened, at that point I'd have to re-work the entire fuel system with larger bore hoses, bigger pumps....and even then, I wouldn't expect it to be a problem selling the Injector Dynamics 1050x's...they're so nice that there'll always be somebody wanting a set.
Pat RUFBTR 04-24-2018 03:32 AM
Hi Spencer, and then they are maybe sufficient also, no need to replace them with this new version! :)
Spenny_b 04-24-2018 04:20 AM
Ok, update time....
The weekend just gone had been scheduled as the worst-case "big day" for getting the engine back into the chassis. There were something like 4 alterations to the plan, to get availability in peoples diaries, and so on. At one point I was looking to get it in midweek the week before, but work commitments dictated otherwise.
Saturday was spent finishing off those niggly jobs, the stragglers at the bottom of any To-Do list that hold no appeal whatsoever. As is always the case, it's actually a useful exercise just going over everything and double-checking. Of course, I'm hoping I've caught all of the small stuff, like boost hoses that were now a little too tight against the coil electrical connectors. One job I had on the whiteboard was to finish the oil pressure/relief spring checks; I'd deliberately left both loose while I went away to find the definitive description on which spring goes into which hole. I also dug out the little spacer now used on the longer, vertical spring. A dip into John's excellent Ultimate Oil Pressure Relief Valve Thread gave me all the reassurance and cross-checks I needed! (thanks Mr C!)
A full-on day just tinkering, very productive rather than frustrating. An early night finish in anticipation of an early, full day on Sunday.
Working solo on Sunday morning, first order of the day was to get the car out, then the engine through from the workshop into the garage (with the engine rotated vertically on the stand and only 2mm clearance to the brickwork!)....then the scary bit, lifting the engine off of the stand. I don't know about you, but seeing mortgage-levels of engine dangling 3ft off the ground, and wrestling the P201 basket off from the engine stand, is terrifying and needs a few brave pills. The one piece of garage equipment I don't have, is a lifting bar with the screw thread, that you can adjust the angle of.
http://img.photobucket.com/albums/v2...d/IMG_2705.jpg
http://img.photobucket.com/albums/v2...d/IMG_2710.jpg
Anyway, t'was done, and seeing the engine safely sitting on the ATV hydraulic jack meant I could take a well earned coffee break (no beers yet...). P201 removed, new flywheel bolts torqued up and the clutch back on, next job was the piece of tinware that sits above the 1-2-3 oil scavenge pump; with the P201 installed it simply won't allow you to install it. Oil scavenge pump return line also fitted, everything routed out of the way from the throttle linkage (harnesses mainly) and it's time to get the transmission mated.
It was at this point that my Brother happened to pop in on his way back from golf. Silly boy. Things are starting to get really heavy now, so another pair of hands to manoeuvre everything was very useful. The next 4 hours were spent carefully orchestrating each piece of equipment, in exactly the right order, to get the engine/box back in 5mm at a time (I kid you not).
http://img.photobucket.com/albums/v2...d/IMG_2711.jpg
http://img.photobucket.com/albums/v2...d/IMG_2709.jpg
Driveshaft clearance is the usual ballache, clearing the transmissions CWP housing, while making sure the stabilising arms don't foul the clutch line that crosses the transmission tunnel. Lots of "spinning plates" to keep an eye on, so Ollie's help was truly invaluable. Despite this, I feel like I had a 12hr HIIT workout throughout the day and only today am I really feeling the effects of it!! I must've smacked my head on the bloody bumper support brackets (sharp) more times that I can remember.
And that was pretty-much it for the day. Exhausted, hot but pretty jubilant that nothing had gone wrong, no cock-ups and the car is now getting back towards it's correct stance. It always amazes me how different and small it looks when sitting correctly rather than at SUV height, "sans drivetrain".
http://img.photobucket.com/albums/v2...d/IMG_2715.jpg
http://img.photobucket.com/albums/v2...d/IMG_2713.jpg
Bumper, heat shields and covers will remain off the car until after all the hub dyno calibration work is complete; makes no sense to fit it all back only to find it needs removing to nip something up, or replace a part, with the dyno facility clock ticking.
However, lots of plumbing and hooking-up of stuff to now be done before I can get Sam down here to build a base map to fire the engine up with, run it in and perform any snagging fixes. I'm aiming for three weekends time for that; this weekend is too close, the following weekend Lucy and I are off to finish our PADI Open Water, do our Advanced OW and also our deep diving certification...so that should give me plenty of time to get it done, interior back in and ready to go.
Pat RUFBTR 04-24-2018 04:42 AM
Great Spencer!
I am disappointed, me who considered in you obsessive on the cleanliness, you have not still had time to clean all the metallic shavings? :D
Spenny_b 04-24-2018 06:01 AM
Originally Posted by Pat RUFBTR (Post 10013110)
Great Spencer!
Haha!! Yes, that is slack of me not to have cleaned the lathe after I last used it...think of it as being more authentic!
(As an apprentice at college, nobody in the machine shop would be allowed to leave for the day until every single tool had been returned to Stores, and every machine was immaculately cleaned and re-oiled. "Old habits die easy"....er, no, that's not the saying, is it...)
304065 04-28-2018 07:54 AM
I assume you were using the Beck's as a cutting fluid.
Spenny_b 04-29-2018 02:05 PM
Lol! Nah, I drink the cheap stuff, and only use the good stuff for suds ;):D
Pat RUFBTR 05-13-2018 03:39 AM
Hi Spencer, no news for a little while, I hope that everything goes well! ;)
Pat
Spenny_b 05-17-2018 11:26 AM
Hey Pat, yes, sorry, been busy with many things the last few weeks, not much opportunity to update the thread.
Things are moving along steadily. After getting the engine and transmission back in, I didn't have any time to play with the car for a couple of weeks; work commitments, diving trip, projects on the other cars...
A couple of weekends ago I was able to do a lot of the "top side" plumbing in the engine bay - connecting all the oil breathers, vacuum lines and so on. The A/C is now back on the engine, plumbed in, as is the power steering pump. I still need to connect the throttle linkage and the air intake snorkel & filter.
As I predicted, it's only when you get the engine installed that you can accurately know which plumbing fittings would be needed for the water cooling circuit, and so it has proved to be. Only two changes required; the first is a 90º fitting for the header tank outlet (I had a 135º fitting, but this pushes the hose too close to where the air intake will sit). The second fitting is an M14 > -8AN male/male adapter for the turbo centre housing. I previously had a banjo connection mating to the extension piece I made, but this fouls the exhaust system (LH silencer tailpipe). All easy stuff to fit.
http://img.photobucket.com/albums/v2...d/IMG_2870.jpg
http://img.photobucket.com/albums/v2...d/IMG_2841.jpg
http://img.photobucket.com/albums/v2...d/IMG_2840.jpg
Last weekend I spent a day or so removing the oil tank; it's not a job I forgot to do, more a job that I kept putting off! But it needed to be done so that I could flush out any last remaining dregs of oil. A good job now done, the whole oil circuit has now been flushed through in readiness for the new oil.
http://img.photobucket.com/albums/v2...d/IMG_2842.jpg
Last night I had a kick-up-the-bum phonecall from Chris - although he doesn't know it was a kick-up-the-bum call, it was a great chat to catchup, but somehow after we speak I always feel completely motivated to get back out into the workshop and get stuff done. In that remaining 3 hours or so of the evening, I think I got more items crossed off the list that I did the previous weekend!!
-Starter motor connected
-Reverse switch on transmission connected/routed/tethered
-Transmission tail stabiliser bars connected
-Water cooling circuit bleed hose cut to length and fitted
-RHS traction control timing wheel fitted, and driveshaft connected/torqued
-RHS sharkfin re-fitted, inner arch installed
-Oil feed and return lines fitted and P-clipped
-Hot air hoses for the HVAC fitted (the rear pipework, not front)
-Clutch slave cylinder pipe attached to transmission mount
Tonights job is to finish the HVAC hosing, connect the gear linkage, LHS driveshaft/TC timing wheel/TC hall effect sensor, then get the car lowered so that I can continue the engine bay work.
After that, it's time to route the ECU harness in the cabin under the carpet, make a new mounting plate for the ECU (and other parts of the system), then refit the interior...finally. I can then get the passenger seat out of my house! Dare I say it, but then I think we're really close to the car being ready for Sam to come and build a fire-up map. Gulp.
Pat RUFBTR 05-17-2018 02:37 PM
Good evening Spencer, ah, I am reassured! :D You very well moved forward on your work, your car is going to be great!
304065 05-18-2018 07:32 AM
Originally Posted by Spenny_b (Post 10040663)
La la la la * * * * I think we're really close to the car being ready for Sam to come and build a fire-up map * * * *
Hallelujah! THIS is great news!
Spenny_b 05-18-2018 01:30 PM
:D:D
Hoping that the clement weather predicted for this weekend will enable me to get the car down and out of the garage, to get the interior back together.
My next trick will be to try and get the car up to where the dyno is. Should be easy, yes? Oh no...UK legislation means that I need to commission somebody who holds an "O License"...basically somebody who is allowed to transport vehicles that aren't MoT'd and have roadtax (ie mine, until its mapped and we can get it through the annual roadworthyness checks, emissions, etc). The big low-loading trucks that are EVERYWHERE are only allowed to transport road legal, crashed or broken down vehicles. FFS. Bloody red tape.
Or speak to a mate very nicely and see if they can trailer it there and back....riskier, but said mate is extremely experienced with doing such things (I'm not, I've never towed anything before).
So, this is going to be a logistical headache, but sure we'll get there somehow.
Spenny_b 05-21-2018 02:46 PM
Quick update, no need for any pics.
All the underside work is now done, apart from installing the transmission tunnel cover and the plastic transmission cover; we'll keep those off for inspection when firing it up.
Unbelievably, it took most of yesterday to route the 5 sections of the chassis harness to the right places. Tremendously difficult when you can neither sit up properly under the car, nor lie down - perhaps the best abs workout I'm likely to do! Routing things around, up, over, under and through places that are now being filled with big lumps of aluminium just takes care and attention. Deliberation on various options to ensure that nothing will abrade or get pinched.
All 4 wheels now have their traction control harness fixed in place, the water cooling circuit is connected and power from the starter +VE is hooked up.
The cabin section of the harness is all now in place, discretely hidden under the carpets and running through channels I've made in the sound deadening.
The car is now back on it's wheels, and after the coffee that's currently brewing, some of the rear trim will go back in.
The final water connection from the header tank to the circuit will get fitted later as well - this could be tricky, doing it in-situ - the push fit connections are not the easiest to get on even when you have everything on the bench; we'll see.
Throttle cable is now reattached - a lot easier than I was anticipating, as you can't even see it under the intake runners.
In other news....
I've made progress on transportation; a recommended company (independently recommended by 2 separate friends) has come in very reasonable, and only need 3-4 days notice and use an open low-loader truck. A second Google hit for a local(ish) specialist have also got back to me, about double the price, but will transport it in an enclosed race shuttle trailer. Hmmm...
Also, as of this evening, Sam is now scheduled to come down here on Saturday for first fire-up!! Beyond excited.
kevinbodman930 05-21-2018 03:07 PM
Sounds like a brand new chapter for the book.You must be over the moon with excitement.I can't wait to hear about the next update.
Spenny_b 05-21-2018 04:36 PM
Cheers Kevin, yes, it's equal parts excitement mixed with sheer terror, lest the same thing happen all over again. No reason why it should, completely different parts, but there's always a nagging doubt at the back of my mind.
Pat RUFBTR 05-22-2018 02:14 PM
Hi Spencer, I understand your state, it is an apprehension because you enormously worked on your car, everything is fine take place, I wish it to you and we wish it all on this forum. ;)
m42racer 05-22-2018 04:19 PM
[QUOTE=Spenny_b;10041982]:D:D
A few years ago, we tipped all of your tea into the sea because of "English red tape"!!
Figured you guys would have had enough of that BS by now.
kevinbodman930 05-22-2018 04:26 PM
That's more like yellow police tape.WOW.
Spenny_b 05-25-2018 01:46 PM
[QUOTE=m42racer;10046639]
Originally Posted by Spenny_b (Post 10041982)
:D:D
Ahh, you see, there's too many idiots in Whitehall making very nice salaries on the back of meaningless and obstructive legislation. And tax.
Spenny_b 05-28-2018 04:54 AM
Slight change of plan; Simon from Sileck said he'd like to be here for first fire-up, entirely makes sense just in case there's a wiring input/output that needs swapping over to a different channel, or other such adjustments.
So, a quick change of plans to align diaries, and it'll now be this coming Sunday.
The final connection to the water cooling circuit has been made; so much for doing it in-situ - no hope, requires far more pushing/shoving than you can do with the hose connected. Don't know why I didn't just take it off to start with, far easier.
During the week I spent a few evenings refitting all of the interior trim, sticking the carpets back down again, replacing tired trim screws/cups with new ones I bought 6yrs ago. It's come up nice! I've not replaced the LH passenger seat yet; still need to make a new mounting plate for the ECU, but will leave it out until we're sure we don't need to tamper with the harness.
And that's about it for the time being.....nothing much else to report until next weekend.
