Carburetor question(s)
Do PMO carbs take IDA style main jets and air correctors? and......
are 40 PMO's the right choice for a high revving 2.8/2.9 motor or would the 46's be more appropriate.
Thanks in advance for the feedback.
Tom B.
Old 09-06-2011, 01:31 PM
Jets are Webber type. I run 46 mm on a 3.0 with GE 60 cams. Your best choice will be determined by your setup. You need to share;
CR
Cams
Piston type
Head
Ignition system
Fuel
RPM range
More info = better answers.
Tell it like it is or don't tell it at all.
Old 09-06-2011, 02:17 PM
Tom B.
Tom,
PMO's take Weber IDA idle jets and IDF mains, A/C's, and emulsion tubes.
46's are the right ones for a high-revving engine of that size. Tune the power curve with main venturi sizing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-06-2011, 03:29 PM
