millarg's Avatar
Question Intake manifold studs
Removing the CIS system from my 78SC,
4 of the 12 nuts came off with the stud attached.
Is this common?
Should I reuse the studs?
Is it recommended to replace all of the nuts when putting the intake back on the engine?
Thanks in advance,
Glen 78SC(D) EFI Targa
Old 09-26-2011, 09:01 AM
Use new.. use RED loctite into the block. I put a little antisieze on the outside threads, but many will tell you that this messes up your torque values
Old 09-26-2011, 09:17 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Very common with the Exhaust one but 1st time I read about the ones from the Intake.
I use new nuts when I put mine back on.
Who Will Live... Will See
Old 09-26-2011, 09:18 AM
millarg's Avatar
Many thanks guys.
Old 09-26-2011, 10:04 AM
