ROW '78 911 Targa
timmy2's Avatar
Camshaft expert opinions needed
Tore down my '78 3.0 ROW tonight due to broken lower stud left side. 81,000 miles on engine. Everything looks normal while disassembling. No evidence of blow by or anything as a result of the one broken stud. I was measuring valve clearances for first time when I found the broken stud. New car to me this summer, read more here: Finally, back in the game!
While inspecting the left camshaft (930.105.147.08) I found all 3 exhaust lobes to have pitting on top (peak) of lobe as in attached pics.
The right hand side has no blemishes what so ever. The rockers are all nice. Cam towers are good, this is the only problem I've found other than the broken stud.
Do I need a regrind on this cam or is it going to last another 80,000 miles until I need a rebuild?
Possible cause of this wear? Is it from the hack mechanic that liked using black rtv on the leaks on this engine and may not have set the valves right?
Anyone have a spare one if this one is toast?
Thanks in advance for your advice, I will be acting quickly on this as there is nothing like a fall cruise on the Oregon coast!
Cylinder 1:
Cylinder 2:
Cylinder 3:
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-29-2011, 09:28 PM
Max Sluiter
Flieger's Avatar
I'm not an expert but I would not want to use that in my engine.
Old 09-29-2011, 10:01 PM
ROW '78 911 Targa
timmy2's Avatar
If camgrinder told me to send it in for an easy fix or exchange I'd be packaging it up already!
I'm hoping a quick weld and profile grind and the 3 bad lobes are fixed.
Dennis
Old 09-29-2011, 10:25 PM
Those cams need to be either hard-welded and reground or replaced. Rockers should be rebuilt as well.
Look to see if the spraybar holes are blocked and make sure you are using an oil that contains the proper amounts of ZDDP.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-30-2011, 12:00 AM
camgrinder's Avatar
Looks like a little more than the usual wear you see on the 3.0 cams. But still easy to repair. For some reason the 1978 thru 1981 cams always have the most wear.
John Dougherty
Dougherty Racing Cams
Old 09-30-2011, 08:23 AM
