Phrog's Avatar
2.4L pistons, What to use?
Hello:
I'm getting ready to re-build a 2.4L engine and see that J&E doesn't make pistons smaller than 2.7L. What is everyone using for new pistons in a 2.4?
Thanks,
Kevin
Kevin
84 911 Carrera
71 911E Vintage Race Car
25 Ford Explorer ST
20 Subaru Crosstrek
Old 10-03-2011, 07:40 PM
Do more research. I'm running JE's in my 2.4 with S cams. Check with our host first. If you strike out, I can point you to a source.
Good luck,
Dana
Old 10-03-2011, 08:34 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
JE will custom make a set of 6 for you in 2.4 l size with what ever CR you want. 9.0/1 CR makes for a nice boost in HP. They just don't have them off the shelf. EBS (engine builder supply co) will also abe able to get you a matched set of P/C (nicklecell) in 2.4 L.
chris
73 911 E
Old 10-04-2011, 12:10 PM
barryr's Avatar
I've had 2.2 "S" pistions with GE40 cams for years. I think the compression works out to be 10.3? Premium gas required.
Barry
Old 10-12-2011, 11:56 AM
haycait911's Avatar
I've got 2.2 'E' pistons. better and cheaper than JE.
Old 10-13-2011, 11:29 PM
haycait911's Avatar
here you go, and an honest seller too..................
Mahle 2.2S Pistons
Old 10-14-2011, 06:55 PM
John Eriksen
Dear Phrog,
I have just completed rebuilding my 1973.5 - i have used the mahle 2.2S cylinders and pistons - not sure if it matters if t, e or s - now it has a compression ratio of 9.6.1 -i have fitted rebuild zenith carbs and E-cams. The car runs great is much more of a sports car than before. Now i can easily keep up with a 2.2S on the track. I think the whole conversion Will cost you abt. USD 6500,- which is not too bad considering
Old 10-17-2011, 02:31 PM
