Mounts
I have not used the Wevo units but have heard good things, You need some compliance with still being able to limit torque movement for the shift linkage on the track/hotrod cars. Solid mounts were the quick and dirty way but created alot of problems from cracking all kinds of things to the fuel issues in carbs.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-03-2011, 06:08 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I'm not nearly as concerned with engine performance as it relates to harmonic vibration as I am with damage related to that vibration.
The mounts we use are the club sport mounts (aka Cabriolet mounts)
911 375 043 07.
We have used the Wevo mounts at the request of a few customers and they seem to be a great product. That is the impression I have of all of the Wevo products.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-03-2011, 09:01 AM
Hi Scott,
I use either Wevo's (blue or black, depending on application) or the factory Clubsport (cabrio) rubber ones.
Same recommendations for all EFI engines as it does improve shifting during high loads.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-03-2011, 09:52 AM
304065's Avatar
FYI, the factory clubsport mounts have a blue paint mark near the stamped number.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-03-2011, 01:04 PM
Thanks for the info guys. I haven't tried the black Wevo mounts but may do so over the winter.
Old 11-04-2011, 04:27 AM
After the next project
x98boardwell's Avatar
Guys, as an update. I installed the carbs on the car... seems to run well but my fuel pressure is reading just below 2 psi... more like 1.8 or 1.9 PSI.. Is this bad? I heard that it should be around 3 or possibly higher.
Thanks,
Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 11-11-2011, 06:27 PM
