Red face Engine Installation Issues
Normally I've been able to search through the forum and pull out any information I need, but now I'm stumped.
I rebuilt my engine, and put in a rebuilt transmission.
When I put the engine and transmission back in, I ran into a problem.
The engine/transmission are at the wrong angle.
The transmission is too high in the front. The shift linkage shaft instead of being centered in the tunnel hole like it was when I took it out is very near the top.
The angle it is sitting at interferes with the throttle linkage that comes out of the tunnel, and the angle of the shift shaft is so much that I cannot connect the shift linkage at all.
All I did was jack the engine and transmission up, put in the the four bolts that hold it in and tighten them up, I can't figure out what is causing the front to be so much higher then it was before.
Am I supposed to shim the front mounts to adjust the engine/tranny angle?
I haven't seen anyone with this issue, any help is greatly appreciated.
Paul
Old 10-30-2011, 08:52 AM
sjf911's Avatar
It should be a straight "drop-in". Are the transmission cross-member/mounts oriented correctly? How about the engine mount? Post some photo's.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-30-2011, 12:07 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Sounds like a tranny mount issue. Did you have the mounts off the cross-arm? Are you using the same parts that came off or different ones? The only shim I have seen is between the tranny and the mount which makes your situation worse.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 10-30-2011, 02:35 PM
trans mount upside down?
Old 10-31-2011, 08:46 AM
Post a picture.......
Possible. Post a picture so we'll know what and how you have installed it.
Tony
Old 10-31-2011, 09:14 AM
Tags
tranny engine mout shims
