Location: behind the redwood curtain, (humboldt county) california
Originally Posted by lightbulb8817 View Post
Hoping you got your answer and others can chime in on a separate but related question...
How does the cylinder head temperature correlate to the engine oil temperature?
Reason I ask is because I'd like to program my front-mounted engine oil cooler to turn on when the oil temperature reaches a certain number (>210-220F). However, I would need an temp sensor somewhere in the circuit, which I'm having trouble tapping into cleanly. If the CHT somewhat correlates to engine oil temp, I'm thinking just use that as sensor to trigger oil cooler fan. In other words, does 250F CHT correspond with 210F engine oil temp generally speaking?
The engine oil temp wouldn't help with tuning your motor due to the amount of time it takes for the oil temp get up to adequate levels.
Oil temp does not have a linear relationship to engine temp, primarily because of the thermostat(S) in the system and the oil coolers. CHT would be much better.
I once ran washer shaped sensors under the spark plugs on a turbo 914, but had difficulty securing the washers reliably.
I believe Elephant sells an oil temp probe that is inserted in the fins of the cooler to switch a relay on to the fan.
chris
Old 02-08-2022, 07:48 AM
Originally Posted by proffighter View Post
Used a Bosch sensor on my SDS EFI like other before
Do you have the Bosch part number for that sensor? It looks as though you are using the end of the sensor to clamp the bracket and wedge the sensor tip onto one of the fins to hold it in place?
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra
Old 02-10-2022, 09:23 PM
Walt Fricke's Avatar
Looks like tightening the sensor clamps it all in place - clever.
Old 02-14-2022, 02:31 PM
Might not be good for the sensor tho?
I'm wondering if there is enough meat in the head, to bore the 10mm hole, and thread it, so the sensor can go straight into the head itself...
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-14-2022, 02:35 PM
Walt, I agree... Seems very ingenious.
Mike, can you expand on your concern? I see a concern with pressure on the tip if the area below the threads is insulated and not one piece with the threaded area. I would think the direct contact is a good thing if one piece? I suspect the sensor reading would be more accurate with direct contact with the head. I do wonder if that specific sensor pulls the temp from the end/tip or an average of the whole sensor below the hex.
Old 02-14-2022, 07:07 PM
Racer
winders's Avatar
Agreed...also, the sensor has a lot of airflow around it which would seem to cool it. The Factory head temp sensor is threaded into the head so the part of the sensor that measures the temperature is much less likely to have air flow cooling it.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-14-2022, 07:30 PM
Mike,
Yes, good idea. Many bolt knock sensor bridges to the bottom of the heads successfully so there is no reason not to drill and tap for a temp sensor.
Old 02-17-2022, 01:51 PM
