Where to find Piston Squirters in the US
I ordered from our host and they are not in stock and will take a month and cost a premium to get. Any ideas who might have them in the US? Thanks in advance.
Old 12-07-2011, 05:04 PM
Did you try Sunset?
Old 12-07-2011, 06:38 PM
brads911sc's Avatar
try a dealer? amazing what they have in stock sometimes...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 12-07-2011, 07:40 PM
squirters
I have some in stock, if you have a part # or a outlet size and length I may have what you need
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-08-2011, 06:58 AM
Thanks all for all of the responses. I am looking for Part Number 93010101500 - the squirters for a 79 930 engine.
Old 12-09-2011, 02:57 PM
gtu935's Avatar
Send a message via AIM to gtu935
why don't you upgrade to 964 squirters?
South Shore Performance (Facebook us)
Freeport NY
FIKSE Dealer
BBS Dealer
Old 12-10-2011, 02:53 PM
AlfonsoR's Avatar
When is it good to change out squirters? I thought they should last quite a while?
"Simplicity is supreme excellence" - James Watt
Old 12-10-2011, 08:24 PM
After you split the engine crankcase....
Alfonso,
Sometimes you could get the clogged oil piston squirter/s to spray better but in some cases cleaning won't make any difference at all. So an appropriate course of action while the engine case is apart, is to replaced the defective ones.
Tony
Old 12-11-2011, 05:09 AM
AlfonsoR's Avatar
Thanks Tony. Is there a way to check squiters for flow? I guess some shops must have flow benches.
Another question, if you "upgrade" to 964 squirters, does that reduce flow/pressure to other critical areas?
Old 12-11-2011, 08:53 AM
