Curil T for Cylinder foot gasket mandatory
Dear rebuilders,
I would like to know if a little layer of Curil T is mandatory for the area of the cylinder foot and spigots. I would like to know if there is experience in leaking in this area? Regards Bob
I've read and heard mixed opinions on the benefits, but in my mind there's really no downside to doing so. In my case I used hylomar on the cylinder base gaskets.
Brian
'82 SC Targa '83 SC Cabriolet |
idc1873
Doesnt Wayne mention Locktite 574?
abit off center
I used nothing, no problems.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Forced Induction Junkie
The base gaskets come pre-treated with a somewhat tacky feel to them. If you decide to add a film of sealer to both sides of the gasket, I would use a soft gasket sealer on the base gaskets such as Curil-T, Hylomar or equivalent.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Manassas, VA
Curil T is a Non-Hardening, Temperature Resistant Sealing Compound and forms an excellent seal where abnormally high internal pressures exist even at extreme temperatures. It is particularly suitable for sealing against mineral oils, synthetic oils, greases, diesel and motor fuels, alcoholic solvents, gases, air, water and seawater. For applications, Curil T has a synthetic base which is ideally suited for sealing combustion engines, turbo blower exhausts, turbines, generators, gearboxes, pumps and other power units as well as threaded connections of all kinds. This is especially appropriate for sealing the Cylinder Head Seal to the Crankcase. Temperature Range of Curil T is approximately -40c to approximately +250c.
1991 964 Polar Silver Metallic Turbo Coupe |
We recommend Curil T for all cylinder bases, even without shims.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
I used Curil-T on both sides, and have absolute no leaks !
Porsche 911 SC 3.0 |
I would rather be driving
I used it on my cylinder bases with no base gaskets/shims. No leaks.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I used the Curil T on both sides of the copper seal. Absolutely no leaks after 4 years!
Roslin
Schleprock
I believe he does. I would disagree with that choice though. My recent engine rebuild has 574 at the cylinder spigots and it's a mess and it hardens. I would choose Curil T over the 574 since the Curil doesn't harden.
That said, i'd go without. Did a top end on my '87 3.2 and removing the heads of course relieved the squeeze on the cylinders and base gaskets. I was worried about the spigots leaking after reassembly because I didn't remove the cylinders and install new base gaskets. In fact, some of the cylinders moved off the case and I had to re-seat the base gaskets. 10K miles later still no leaks. Maybe I got lucky.
Kevin L '86 Carrera "Larry" |
Try not, Do or Do not
Oil leaks are a roll of the dice when rebuilding a 911 engine.
Back in the early 90s a friend was working at the factory and reported to me that Porsche was experiencing a 4% failure rate due to oil leaks on new engines while running in the dyno. These engines were built by factory trained mechanics using new parts. That number seems hideous. If they have that kind of failure rate what chance do we have? Any extra sealant that can be applied with reasonable restraint is good insurance. IMHO
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I used curil t the first time and hylomar the second neither one has leaked and mine is a turbo motor.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Wer bremst verliert
The only motor I built that leaked from the cylinder bases was one I used 574. On all before and all since I've used curial and had no leaks. I am not a pro engine builder and i'm not claiming my results to be conclusive, just my limited experience.
Pulling that motor out and rebuilding it for those leaks was something I don't want to do again.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I read somewhere that Curil T is certified for use in nuclear reactors. Throw a set of thermal reactors on a 2.7 and that's just what you have
I can support the comment regarding the use of Curil T on nuclear reactors from practical experience, we also used 574
. andy Last edited by haasad; 12-26-2011 at 02:10 AM.. |
