Secondhand pistons and cylinders, need to hone the bores?
Hi There
I am just about to start putting my 993 engine back together. I bought a set of 36k mile pistons and cylinders to replace mine and was wondering if I need to deglaze the bores with some scotchbrite. They do not look glazed and the cross hatching is clearly visible. I am using the rings that came with the set, but are replacing the clips that have been removed from the pistons (one side only). I have the rings off of the pistons and have cleaned everything up nicely.
All the best
Berni
Old 12-20-2011, 09:09 AM
Break the glaze with some scotch brite, wont hurt anything.
Bruce
Old 12-20-2011, 11:30 AM
I second the idea of scuffing them. I like using the old rings as well, especially with low miles.
-Andy
Old 12-20-2011, 01:51 PM
Hi Guys
Many thanks for the replies. I will scuff them up.
Berni
Old 12-20-2011, 03:23 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Soap and hot water, ScotchBrite (I like red) and new rings.
A new set of Goetze rings ($140 or so) is cheap insurance.
Pelican Parts - Product Information: 930-103-963-00-M42
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-20-2011, 04:05 PM
The time I bought brand new Goetze rings, they had bigger end gaps than the old rings. They were at the wear limit spec. brand new!
-Andy.
Old 12-23-2011, 12:58 PM
-Andy.
That is very common with off the shelf ring sets. You might try buying individual rings for Mahle Motorsport or Andial. Cost is a little higher but size tends to be closer.
Henry Schmidt
Ph: 760-728-3062
Old 12-23-2011, 01:20 PM
Thanks Henry!
Old 12-23-2011, 01:42 PM
Hi There
I did not actually use any soap and water with the scotchbrite. Just used it dry. Is that OK?
Tks
Berni
Old 12-28-2011, 10:51 AM
Ken911's Avatar
Soapy water washes away the grit, and also breaks up the varnish in the grooves. When i did mine i cleaned them with a red scotchbright and soapy water then put them in the dishwasher. No not married so no problems with the wife *****ing about car parts in the diswasher, or oven for that matter lol.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 12-28-2011, 03:39 PM
Hi Ken
Lucky you.......
I so wanted to put my cam towers in the dishwasher. Not worth the risk in my house though.
Berni
Old 12-28-2011, 04:39 PM
