Originally Posted by expernet View Post
Since the stud is supposed to match the expansion of the case you have to be quick and make sure you are not heating the stud too.
Try wrapping the stud in a wet towel to reduce it's heating relative to the heated case...
Old 01-18-2012, 04:47 PM
Judging from the look of the sealing surfaces and blow by on most of the cyl the studs broke after the engine was sitting.
Bruce
Old 01-18-2012, 05:36 PM
safe's Avatar
So here is what I learned:
The $19.95 screw /stud extractor from Sears is a must have. Makes the job simple
Some studs must still be heated, I heated on the inside of the cylinder barrel along the base of the stud with a good old bernzomatic.
Since the stud is supposed to match the expansion of the case you have to be quick and make sure you are not heating the stud too. I had my helper put torque on the stud and at the right temp it will give, turn fast or it will lock up again.
I am only replacing the lower studs , Mainly because of the stress to the threads (not because I am cheap even though my kids say I am)
Stay tuned for reassembly!
The heat needed is not for "expansion" of the case, its to break the loctite.
With broken studs welding on a nut works great and the heat from welding is enough to break the loctite. Then an impact gun (cheap electric works fine) on the nut.
Magnus
Old 01-19-2012, 02:04 AM
P car addict still using
expernet's Avatar
It's on the road
It' done and on the road, i will get a tag and register this week, a few things to fix but very road worthy.
FYI this is the build sheet
61 356b
69 911t
Old 06-10-2012, 12:53 PM
Senior Advisor
James Brown's Avatar
not bad, oh, by the way, your labor-priceless!
08 Cayenne Turbo
Old 06-11-2012, 02:49 AM
