3.4 Mahle 98mm 9.8 CR - dual ignition needed?
1. Is dual ignition needed for a street car with Mahle 98mm 9.8 CR pistons run with pump gas?
2. The pistons don't look like the CIS and on ones that have a rounded dome that is bulged on one side. Instead, they are flat but slanted from one side to the other. Is the high side installed on the left or right?
Old 01-09-2012, 10:52 AM
MBruns for President
JeremyD's Avatar
In california with 91 octane gas - I'd say yes. But I ran them for years in Florida - and on the track in anger with single plug. The down side with detonation is a pretty big downside.
Old 01-09-2012, 05:36 PM
GrantG's Avatar
Sounds like the Max Moritz pistons which were designed to work with single plug ignition. Posting a photo would be helpful.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 01-09-2012, 06:09 PM
wullah:
Old 01-09-2012, 07:02 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Those are weird looking pistons- the offset valve reliefs. My 98mm Mahle pistons from my recent 3.2 short stroke (SC 3.0L) teardown have deeper pockets (large one is the intake side) and note the tiny pits around the perimeter of the piston
The tiny pits are signs of very slight detonation at the perimeter where clearance between the piston and combustion chamber/head and valve & piston is tightest. Mine has been single plug (Electromotive crankfire) for many years and the engine is a carbureted "race" engine for whatever that's worth. It was typically run on 104 or 110 race gas, occasionally 93 octane pump gas, with a lot of advance (30+ degrees). Twin plug is good insurance IMO.
BTW the "E" on the piston is for the INTAKE side. Yes I said intake because E is German for ....... I don't know. I just know what i've seen in the factory documentation like my recent read thru a 964-993 after sales training manual for engine repair
Kevin L
'86 Carrera "Larry"
Old 01-09-2012, 09:22 PM
wullah:
Those were specifically designed & made for single-ignition and thats how they should be installed.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-09-2012, 10:16 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Steve,
Thanks for the clarification. Do you know why the valve reliefs are skewed like that? It seems like a way of replicating the original CIS & Motronic swirl-dome pistons with a taller dome that has the necessary valve relief.
Kevin L
'86 Carrera "Larry"
Old 01-10-2012, 09:20 AM
Originally Posted by KTL View Post
Steve,
Sure,......these domes are asymmetrical and the valve reliefs reflect that,...
Remember, these were made for Motronic engines which have different swirl characteristics than CIS engines and the wedge domes were intended to help improve squish at CR's above 9.5:1 with single-plug operation.
The valve reliefs can be cut a little bit for more camshaft choices.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-10-2012, 10:20 AM
So, if single plug, then is 91 octane ok for street purposes?
Old 01-10-2012, 10:52 AM
Yes, provided you're not too aggressive with timing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-10-2012, 11:14 AM
Thank you for sharing your knowledge.
Old 01-10-2012, 11:55 AM
What are most aggressive camshafts to use with these type of pistons without cutting any material from valve reliefs and 3.2 Motronic intake? 964 or 993SS? And what about after cutting?
911 -87 Marine Blue, 3.5 twin plugged, DC24, 22/23 sways, 22/29 bars, PB front and rear, G50 with Cup LSD, Heigo CS cage
911 -73 track project
Old 01-10-2012, 10:26 PM
964 ones do not require any machine work.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-10-2012, 10:32 PM
Phew - 7 months for bathroom remodel. About ready to get back in to this. Sorry to beat the dual ignition thing to death, but here are a couple curve balls:
1. this engine is going into my 914 since I was concerned the 9.8 c/r wouldn't pass smog test in my non-cat '77 911. The 914 only has a fan assisted 8x10 aux oil cooler. Before, a stock 3.2 never got over 210F.
2. I will try to get a chip made by Steve or Loren who hopefully can accommodate this config. But really, I don't know what ign timing will be used.
I'd really like to get this engine right the first time. If dual ignition will really help with temps and detonation, so be it. But if it's truly not needed, fine.
Old 08-25-2012, 12:04 PM
You do NOT want to use twin-ignition with these pistons: single ignition only and be conservative about CR given the 91 octane fuel you have.
Steve will know what to do for Motronic software for you,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-25-2012, 03:47 PM
You need a cooler. Check the calibration between the sender and gauge.
The engine lid needs to be double grill modified. The stock lid has a metal panel and restricts the air going to the motor.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-29-2012, 09:16 PM
JED
ARCSinAK's Avatar
Steve is unreal, we should show our collective appreciation. Wonder what puts a smile on Steve's face! Ideas?
Old 08-29-2012, 10:34 PM
Under the radar
Trackrash's Avatar
Are these style of piston still available. If so in 95 x 70?
Thanks,
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-30-2012, 04:05 PM
Steve has been very helpful and giving of his time to me. Supporting his business is certainly a good start.
Steve is definitely one of the good guys in the Porsche world. I've only owned my 911 for 14 months and I'm hooked( I'm a former Corvette and muscle car guy). Guys like him and Wayne have really helped my Porsche experience.
Dean
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Old 08-30-2012, 04:57 PM
Thanks,
Gordon,
Those pistons were only made in 98mm.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-30-2012, 10:30 PM
