82 SC Rebuild
Are porsche parameters close enough for the balance of the motor, or should I have the motor balanced and blueprinted. I think the shop said they could get to 1 Gram.
This is a stock 3.0 SC motor. Thanks, Robert |
Air Medal or two
Its kind of redundant to shoot for 1 gram and not go for "0"
With 0 at least you are knocking on the door of Purrfection...and its in truth not much more work. To shoot for 1 gram is actually saying plus or minus 1 which equals 2 ! NOT good enough BUT you probably will never know it...I am just a anile bastard about stuff i can make better. A Gram scale these days are cheap !
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Wer bremst verliert
You may be able to do it yourself...and get pretty close to bang on by mixing/matching the lightest piston to the heaviest pin, etc.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Air Medal or two
You find your lightest Make all others match with a few different wheels and grinders
Do a bit of research on the net. There are some real good ideas that will get you end for end. CHEAP I read somewhere 1 gram is like 30 lbs out of balance..........
