low compression
been told that the compression in my 2.2 is low specially in the second cylinder does this mean i nedd a top end rebuild many thanks brian
Old 01-25-2012, 12:38 PM
You want to check it in comparison to the other 5 and that will let you know. There can be guides needed or cutting the faces of the valve or just a carbon build up on the valve face keeping it from closing completely.
If the engine is on the floor, any numbers would be suspect without running it through several heat cycles.
Bruce
Old 01-25-2012, 01:05 PM
reply
hi bruce the engine is in the car the rest of the cylinders are low but the number 2 is alot lower than the rest any advice would be great
Old 01-25-2012, 01:08 PM
What are the numbers?
Tell it like it is or don't tell it at all.
Old 01-25-2012, 03:25 PM
Walt Fricke's Avatar
And what altitude do you live at?
Old 01-25-2012, 04:07 PM
You really need to do a leak-down test to diagnose the problem. With a leak-down, you can listen for the source of the leak and get a much better idea where the problem is.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-26-2012, 07:35 AM
