Proper injector and fuel line torque
What are you guys torquing these respective items down to? I don't want to over tighten and damage threads or connectors.
Old 02-22-2012, 01:54 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Use anti seize and snug them down. There is no torque value that I have seen and with the nut and ferrell end (injector) it seals on the taper so there is no need to jump on it. The fuel distributor end has cooper washers so go easy on them as well.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-22-2012, 04:25 PM
