Proper injector and fuel line torque
What are you guys torquing these respective items down to? I don't want to over tighten and damage threads or connectors.
Thanks |
Try not, Do or Do not
Use anti seize and snug them down. There is no torque value that I have seen and with the nut and ferrell end (injector) it seals on the taper so there is no need to jump on it. The fuel distributor end has cooper washers so go easy on them as well.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
